clutch question.
i have a 90 civic hatch with a D15B1 and 4 speed in it, and my clutch is about shot.
(side note: i have a D15B7 pulled apart and a *5 speed cable tranny sitting in my garage)
i want to buy a clutch that will fit my D15b1/4speed combo for now, but will also fit my D15b7/5speed combo when i'm ready to make the swap in the future.
am i going to be using the same clutch regardless?
what spline count, shaft diameter, clutch diameter, disc diameter should i be keeping an eye out for?
keep in mind im trying to do it on the cheap, dont have to have a stage 1 or 2 clutch.. unless you know where i can get one for cheap.. like $100-$200 range.
*i'll have to get back to you on what year my 5 speed cable tranny came out of. i wanna say a 91 dx hatch. if it makes a difference?? i know the 88's had a different spline count, jus sayin..
THANKS!
THANKS!
thanks, but i know what transmissions i can use. i just had a CLUTCH question.
maybe i should use a clutch that's works on any 89-91 L3 cable tranny...
i guess my real question was.. does a clutch from a 92-95 civic work for a 88-91 civic?
i know a cable tranny can bolt up to a d15b7... it's just no one ever mentions what clutch they use in that application.. are the hyrdo tranny's clutch not compatible with a cable tranny clutch??
Anyone with an S1 tranny and upgraded clutch/flywheel? I have a question for you (Or if you might kn
Fred n J_v2.0
15
Jul 24, 2003 05:21 AM
