b20 swap problems and questions....
Old Mar 24, 2013 | 10:04 PM
egcrazed's Avatar
Default b20 swap problems and questions....
hey so i just did a b20b swap in my car im currently not running a proper ecu... was waiting till i put a b16 head on it and do a tune and everything at the same time but im having a few problems as it sits and wonder what everyone thinks it could be i was told and also think its my ecu atm
-bogs at low rpm after about 4-4.5k rpm it stops
-shitty start ups some times
-reving at low rpms its a lot louder then when i hit around 4.5k
new to cars and trying to learn as my buddies know a lot more then me atm lol just wanna know if its an engine problem or needs a better ecu ( ecu was for a h22 )
thanks b.
Old Mar 24, 2013 | 11:19 PM
89 SI zero's Avatar
Default Re: b20 swap problems and questions....
you won't be able to do anything or have not close to decent drivability until you get an ecu for your engine and you'll have to tune it when you put the b16 head on as well
Old Mar 24, 2013 | 11:40 PM
egcrazed's Avatar
so the ecu is the problem? i kno i needa new one but thats wat should be causing the problem no? and ya i always already planning on getting thee tune after the head
Old Mar 24, 2013 | 11:54 PM
jbpnoman's Avatar
Even if the ECU isn't the problem, we can't even begin to diagnose the problem until you run a proper ECU. While you're working on getting the right ECU, check your timing.
Old Mar 25, 2013 | 12:02 AM
egcrazed's Avatar
will do ty
Old Mar 25, 2013 | 12:10 AM
egcrazed's Avatar
guessing p75 with the right deletes?
Old Mar 25, 2013 | 12:14 AM
jbpnoman's Avatar
The PHK is for the B20B/Z.
Cass_EF
17
Jan 11, 2016 08:55 AM
Fast50racer228
Engine Management and Tuning
Oct 12, 2010 11:55 PM
tmramsburg
Apr 25, 2006 01:34 PM
91civichatchCrX
Jan 26, 2006 09:14 PM
1hotcivicSi
Feb 19, 2004 07:12 AM
