Fuel Pump 94 accord
Old Mar 24, 2013 | 04:48 PM
Trey Newton's Avatar
Default Fuel Pump 94 accord
So...I keep seeing all over the internet that you can access the fuel pump underneath the back seat of the car, then I see you have to drop the tank. I would like to know why I've seen pics of it actually under the back seat because that's not the case with my 94 accord. What is the real truth behind the fuel pump. I have tried replacing the relay and that's not the issue, are there any other possibilities of what could be the issue?
Old Mar 24, 2013 | 05:27 PM
92 civic ex 4dr's Avatar
Relay, fuse, bad ground, bad wiring.
Yes you have to drop the tank. I cut out above the pump and installed hinges and a latch with rubber to create a seal. Now i have access to the pump w/o having to drop the tank because if i can do it easier and faster then i will.
Smarter not harder.
Posted from Honda-tech.com App for Android
Old Mar 24, 2013 | 07:26 PM
nus_dogg's Avatar
Default Re: Fuel Pump 94 accord
You will need to drop the gas tank to get to the fuel pump.
othermeans
Oct 20, 2018 08:05 AM
Big D'
Dec 21, 2017 10:19 PM
podom
Mar 17, 2016 06:46 PM
94accord89B
Jun 16, 2012 06:27 PM
Blue94Accord
May 13, 2010 05:59 AM
