92-95 CIVIC HEADLIGHT WARNING BUZZER INSTALL
Old Mar 24, 2013 | 03:18 PM
Moms 94's Avatar
Default 92-95 CIVIC HEADLIGHT WARNING BUZZER INSTALL
Tired of coming out to a dead battery because you left your headlights on?
Here's simple instructions for wiring up a headlight buzzer in your eg/ej civic.
Old Mar 24, 2013 | 03:26 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 92-95 CIVIC HEADLIGHT WARNING BUZZER INSTALL
Hack job.
Old Mar 24, 2013 | 04:23 PM
Moms 94's Avatar
Sorry you feel that way grumblefuck, but it's a solution.
It may not be the "perfect" solution, but it works and
is worth not coming out to a dead battery.
If you have a better solution, POST IT!
Old Mar 24, 2013 | 04:27 PM
The Grumpiest
As I said in a PM there was already a cleaner solution than this rigged contraption.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bdiy%5D-oem-92-95-honda-civic-lights-chime-retrofit-no-radioshack-crap-here-folks-2749779/
But I'm sure that anyone that likes to take shortcuts will appreciate your contribution.
The name calling? Juvenile. Don't like what I said? Report it.
Old Mar 24, 2013 | 04:47 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
This was the solution that was commonly used up until 2010 when I posted the DIY that grumblemarc linked to showing what could be done using all original Honda parts.
While I disagree that this is a "hack job" as there is really very little messing about with wiring that needs to be done to install the buzzer, I do feel it is outdated now that there is a cleaner solution available. It's good in a pinch, I suppose, but I also did not find the buzzer reliable, notably especially on cold winter days (when you really want it most!). It was this trouble I had with it that led me to research my other solution.
Old Mar 24, 2013 | 05:19 PM
angrysmileyface's Avatar
I would side with Deschlong on this one. I've done the ICU conversion after having the buzzer thing. Kinda got tired of the thing going off when the car stalled or had a problem. Its much more pleasing to hear the integra chimes.
Old Mar 24, 2013 | 06:30 PM
Moms 94's Avatar
I completely agree with you Deschong and I had both read your post previously and appreciate the info.
But I needed a temporary solution until I can locate the Acura part. It was never intended as a permanent fix.
It has saved my skin several times. And I agree "hack job" is a bit extreme.
Old Mar 24, 2013 | 06:51 PM
deschlong's Avatar
Loved
Community Favorite
Note that you can also plug and play ANY 96-00 Civic ICU and you will have instant headlight-on warning functionality. You will need to swap the pins like in my DIY for the connector but since 96-00 Civics are likely easier to find than Integras, this option might also suit you. I haven't written up a DIY for this yet as this was a more recent discovery, so you'll have to research the pin swap step yourself by comparing ICU wiring diagrams for both cars in their respective service manuals.
Alternatively, if you also have a rear wiper then you can swap in a 98-01 CR-V ICU and wire in the intermittent REAR wiper functionality ... but that might be a bridge too far.
Old Mar 25, 2013 | 06:36 AM
Moms 94's Avatar
FYI:
http://www.hondapartsunlimited.com
CONTROL UNIT, INTEGRATED - 1996 HONDA CIVIC (38600-S01-A11)
Sale Price: $51.53
Compared at: $73.40
You Save: $21.87
Product ID : 38600-S01-A11
or
CONTROL UNIT, INTEGRATED - 1994 ACURA INTEGRA (38600-ST7-A01)
Sale Price: $178.07
Compared at: $243.30
You Save: $65.23
Product ID : 38600-ST7-A01
Old Mar 25, 2013 | 09:59 AM
deschlong's Avatar
Loved
Community Favorite
^ Yes, if new - those prices are really astronomical. These ICUs are usually about $10 at any junkyard. And since you need the pigtail also, really your only option is a junkyard - that's why I advocate them.
prostreetonline
90
Mar 24, 2013 03:18 PM
D15Bbigred
Jul 19, 2005 06:38 PM
poison
Feb 21, 2002 06:35 AM
