Rear disc conversion on a 1990 civic SI hatch what car can I take the setup from?
Old Mar 24, 2013 | 02:30 PM
BakedAlex's Avatar
Default Rear disc conversion on a 1990 civic SI hatch what car can I take the setup from?
So I have been searching threads and I'm having trouble finding out what cars I can take the rear disc setup from. I know a 90-91 crx SI will fit and also a 90-91 integra setup will fit but why about something off a EG civic or a newer integra? Any suggestions would be appreciated!
Old Mar 24, 2013 | 05:17 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Rear disc conversion on a 1990 civic SI hatch what car can I take the setup from?
I would not get it from a CRX since the E brake cables are shorter and won't reach.
Integra or another civic would be my choice.
Old Mar 24, 2013 | 08:23 PM
BYOB916's Avatar
any integra, i think DA's have rear disc too, just grab the whole setup from a local pick n pull
Old Mar 24, 2013 | 08:45 PM
BakedAlex's Avatar
I bought the whole rear set up off a 1990 Acura Integra, e-brake cables, master cylinder, booster, proportioning valve included too. Installing this Friday hopefully it goes without too much headache. Should I use my stock trailing arms? Any suggestions appreciated
Old Mar 24, 2013 | 08:59 PM
BYOB916's Avatar
i've never did the conversion but i dont think you needed all that. master cylinder booster etc. i thought it was just the whole knuckle unit and forks
Old Mar 24, 2013 | 10:03 PM
1uzS14's Avatar
I got mine from a 92 RS integra 2dr
e brake cables to fit an EF hatch must be from the 2dr (as opposed to the 4dr DA)
rear trailing arm including brakes and brake hoses from a 2dr or 4dr DA
use your stock EF toe arm
use your stock EF LCA
use your stock EF UCA
use 40/40 brake proportioning valve from 2dr or 4dr DA LS or RS (GSR comes with abs)
I recommend (not required) the replacement of the rear trailing arm bushings (how to vid on YOUTUBE)
If you have the time and/or money, the DA master cylinder and booster will increase brake performance, but are not necessary for the rear disc conversion to function properly
thats pretty much it, any more questions feel free to PM me
Old Mar 25, 2013 | 12:31 PM
Tyson's Avatar
Theres no such thing as a 40/40 valve.
Old Mar 25, 2013 | 09:09 PM
BCGARAGE_ED7's Avatar
I just did a rear disc on my SI with a DA trailing arm and spindle. It all bolts right up, except the DA trailing arm makes the wheel poke an extra. 25 of an inch I believe.
Posted from Honda-tech.com App for Android
Old Mar 25, 2013 | 09:10 PM
Thank you. I don't understand why so many people think it's a ratio. They need to understand that it's a 4040.
Old Apr 1, 2013 | 09:10 PM
ah-lecks's Avatar
Old Apr 1, 2013 | 09:11 PM
ah-lecks's Avatar
Good looking out
Old Apr 15, 2013 | 09:28 PM
BakedAlex's Avatar
Thanks, this info was extremely helpful! I may have used the wrong toe or lca/uca without this post! I've completed the conversion now, I was running the stock booster and master until yesterday and it made a huge difference with the Integra booster and master. Unfortunately I was unable to get the spindle and backing plate separated from the DA trailing arms and had to use them on my car and now the rear tires stick out a little. I'm going to re-do the swap if I can find some spindles that are already separated with no damaged threads and put them on the original RTA's.
Old Apr 15, 2013 | 09:34 PM
BakedAlex's Avatar
Are you having clearance issues? I think my right rear rubs on really really hard turns. I'm riding at stock height with 195/50R15 tires, tons of wheel gap between tire and body. Is rubbing even feasible? Suspension is in good shape still, OEM
Old Apr 15, 2013 | 11:27 PM
waughscf's Avatar
Old Apr 16, 2013 | 04:31 AM
New Fella's Avatar
good info, off to the yard I go
Old Apr 16, 2013 | 04:38 AM
blk_honda112's Avatar
I have one word . Scarebird . http://scarebird.com/index.php?route...product_id=116 . Takes 20 minutes 80 buxs .
Ebrake650
Jan 14, 2008 12:18 PM
jdm4life!
Sep 3, 2005 05:40 AM
Hybrid7
Jun 3, 2005 07:23 PM
SpoonRex
May 9, 2005 11:19 AM
