random oem stuff dc eg ef for sale
Prices dont include shipping and are open to trades or negotiation
3 gsr pistons with rods 15
4 ls pistons with rods 25
Power steering pump sold
2 19t water pumps free
Auto trans t bracket b series 10
B18b lower timing belt cover free
Drivers side airbag will not ship 20 acura logo in center
Blinker to bumper bracket for usdm integra front end only have one not sure which side free
Detachable steering wheel hub adapter 5
Dc bumper crash bar 5
Stock ls intake tubing and the piece that goes between the bumper and tire sold
Winshield washer fluid reservoir for integra sold
Heat shield one that goes above the shift linkage off Integra free
Megan racing test pipe needs to be welded in place 30
B series Alternator bracket lower free
No name front upper strut bar 10 for eg dc may fit other models
Under hood fuse box 20 from dc
Third brake light sold
B series trans torque mount 15
Rear wiper arm and motor from dc free
Obd1 alternator sold b series
Obd2 alternator sold
Dc 2 dr d/s window switch free
2 ls valve covers $25 1 left
Header heat shield both pieces inner and outer b series off an ls free
Aem intake tubing has small cut came from eg sold
B series half shaft sold
Light/wiper switch assembly 15 from an eg
B18 crank pulley sold
Ls stock cams sold
Ls cam gears sold
Obd1 injectors a couple have cracked tips but still work 10 from an ls
Obd2 injectors from jdm b20 sold
Obd1 injector clips 5
Obd2 injector clips 5
Crankshaft timing belt gear one behind crank pulley came from b series motor free
B18a windage trays free
Oil pick up tubes from b18b free
Stock ls shifter 10
D/s air vent free
Knock off type r shift **** has some scratches 10
Mirror switch for dc free
*Gsr intake manifold I believe its been port matched 30 not sure the ports have some grind marks
B16 intake manifold 30
B20 giraffe manifold free
B20 throttle body no map or tps 10
Eg rear seat 30
Eg sedan trunk side carpet free
Dc tan dash free
2 eg/dc passenger side seat rails 10 each
Black passenger side da seat I believe 10
Ef rear side panels , some dumbass cut out holes for 6x9's free
Dc fenders with some damage 5 for both
Aem (I believe) alternator pulley 15
Crx bumper brackets, I believe they bolt to the crash bar to line up the bumper ???. Free
Sun damaged steering wheel from dc free
Aem license plate ring free
Stanley side marker only have 1 5
Drivers side eg headlight broken tabs but glass in near flawless 10
Eg ash tray bezel with pocket and cig lighter 15
Ecu cover plates I think from an ef or eg not sure free
Usdm crx bumper light with primer overspray free
Eg center console blue in color with two cracks look at pics 15 for both pieces
Eg air intake tube sold
Dc a, b, c pillar cover plastics sold
Dc inner fender liners slight damage on one free
B16 cable trans shifter forks free
Jdm sport intercooler 30
94-97 front bumper upper halfs all three have damage or cut tabs free*
Sohc cam gear oem free
Eg I believe ??? Prop valve free not a 40/40
D series alternator bracket sold
Crx radiator overflow tank no cap free
Crx condenser fan free
Dc rear springs oem 15
D series oil cooler 5
B series oil cooler 10
D series breather box free
D series oil pick up tube free
D series a/c bracket with tensioner sold
Blown t3/t4 turbonetics turbo has shaft play 40
B series tubular no name turbo manifold needs werk 10
Eg windshield washer fluid res. 5
Ef windshield washer fluid res. 5
Ef side mirrors 10 one has broken glass*
Eg oem wing 15
Eg pass. Side corner light free
Eg metal piece that the spoiler bolts to 10
Ef under steering wheel panel free
Eg pass side mirror delete plate 5
Eg windshield molding pass. Side only free
Eg dash pocket 5
Eg hatch front and rear bumpers 40 for both need paint
D series trans torque mount 15
Eg steering column cover 5
Plastic velocity stack 5
Eg sedan damaged taillights 35
Coolant hose horseshoe shape 5
Eg antenna cover 5
Hallman manual boost control heavy boost spring 2
Aem cold air Intake extention, the piece that goes down by the wheel well 10
Eg oem tweeters sold
Burnt out ecu pr4 obd1 5 speed 5
Da dohc fender moldings 10
No name front upper strut bar 15
Eg speaker covers. 10 for both
Eg door handle covers, one door handle plastic and one manual window crank lever 10 for all
Eg rear view mirror free
Eg gas filler door free
Eg dc horn buttons free
Crx distributor off of jdm zc single cam motor 15
Injector harness holder, plastic that bolts above fuel rail free
Eg tail light harness 10
Hacked up obd1 under hood wire harness good clips might be missing some 10
4 bolt wastegate old school as hell 25
4 bolt dump tube 15
Eg dc motor mounts kinda beat up two of three center pins slide out shown in pics below sold
http://hondamarketplace.com/showthread.php?t=3133822
