Should I buy this engine??
http://pensacola.craigslist.org/pts/3669147962.html
It is a F22B1 for $150. I posted the link above. Should I buy it, sounds like a deal?
See if you can have him compression test it.
For what he's asking its probably a junked engine that needs a rebuild. You could get rebuild kit and rebuild it yourself, its not hard (if you have the tools and the right manual),
http://www.ebay.com/itm/94-97-Honda-Accord-EX-2-2-VTEC-Engine-Rebuild-Kit-F22B1-/250534176402?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a55002692&vxp=mtr
Those are standard pistons and rings, you probably want oversize.
You get oversize when you overbore the cylinders. You overbore them because you can return the engine to factory specifications that way. An engine that has a lot of wear in the cylinder walls will need to be bored out and have oversized pistons installed.
If however the engine bores and piston-to-wall clearance is in specification,then all you would need to do is install new rings. Make sure you put the pistons in the same cylinder you took them out of, mark them.
