98 Accord Fuel Trim -100.6 and P0420
Old Mar 23, 2013 | 09:12 AM
earn333's Avatar
Default 98 Accord Fuel Trim -100.6 and P0420
I have a 98 accord that will frequently post a P0420 cat code. Looking at the freeze frame data the LTFT3 and STFT3 both indicate -100.6%. Is it possible that the fuel trim is causing the P0420 to post??? If so, any ideas why such out of bounds fuel trims??
Freeze Frame Data
Throttle Position 18.4%
RPM 2031
Load Value 60.7
MAP Sensor 62 KPA
Coolant 197degs
STFT1 -5.1
LTFT1 -1%
STFT3 -100.6
LTFT3 -100.6
Speed 52 MPH
Fuel System 1 Closed
Old Mar 23, 2013 | 12:48 PM
hondamark35's Avatar
Default Re: 98 Accord Fuel Trim -100.6 and P0420
i wouldn't think so. this code is for no good catalyst efficiency. it's based on a differential between upstream and downstream O2 sensors (or lack thereof.) i suspect you would see a P0171 or P0172 if there were truly a fuel trim problem. it's odd that it's off like that but if only P0420 is showing, you should only troubleshoot that. no other drivability issues?
you could confirm it's not just an intermittent fault by clearing the code, bringing the engine to operating temp then driving for a few minutes at 45-50mph. lift off for about 3 seconds (throttle completely closed). if the code returns, replace the cat.
Old Mar 23, 2013 | 01:35 PM
earn333's Avatar
Thanks for the reply... I have cleared the code several times and it always reposts. I removed the O2 sensor in the CAT it had quite a bit of soot on it. The tailpipe also shows soot. I did replace the O2 sensor in the CAT and am waiting to see if it reposts.
Old Mar 23, 2013 | 06:56 PM
hybridmiklo's Avatar
yes it can cause the code p0420.
Old Mar 23, 2013 | 07:18 PM
Please exlain.
Old Mar 24, 2013 | 02:34 AM
earn333's Avatar
Thanks, Any ideas why such a high negative fuel trim??? No real driveability issues, only a slight hesitation some times.
Old Mar 24, 2013 | 11:14 AM
earn333's Avatar
I may need help understanding the scan tool here... THis is a 4 cylinder engine, should there only be 1 set of LTFT and STFT?? THe scan tool outputs 2 sets of fuel trim values for LTFT and STFT (LTFT1, STFT1, LTFT3 and STFT3). Is the LTFT3 and STFT3 from the scan tool bogus if this is a 4 cylinder motor???
Old Mar 25, 2013 | 01:18 AM
holmesnmanny's Avatar
Your problem is either the oxygen sensor or cat here. Not sure why you're fiddling with long and short term fuel curves.
Bigdingo74
Mar 26, 2019 04:03 PM
RA022626
Jul 15, 2015 06:34 PM
mc1427
Mar 12, 2014 03:40 PM
dc4_wHORE
Jan 6, 2010 10:53 AM
mpancha
Feb 27, 2007 05:40 AM
