CRX speed sensor
Old Mar 22, 2013 | 10:07 PM
cmkwood's Avatar
Icon2 CRX speed sensor
I have a 91 crx HF with a D16Y7 swapped in and a 1988 CRX tranny in it. My ECU is flashing a (20)speed sensor and a (17) ELD. Now I know it sounds stupid but I cant find the speed sensor on the CRX 88 trans sooo where is it? And I need a new fuse box if my ELD goes out. right? And where can i get a speed sensor will all 88-91 speed sensors be the same or do i need one off an 88?
Old Mar 23, 2013 | 05:59 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: CRX speed sensor
The speed sensor, the actual sensor, is in the cluster. Those rarely go bad, I have never seen or heard one go bad.
What you want to do is make sure the cable at the transmission is pushed in all the way and making contact with the gear. then make sure the cable is also connected securely at the back of the cluster. If the cable is OK and it turns as the car moves and it's conected to the back of the cluster, then look for missing screws on the back of the cluster. There is one screw directly behind the speedometer that has a label I think SP that HAS to be there. If the screw is missing, there is no speedo signal going back to the ECU.
Does your speedo work?
Old Mar 23, 2013 | 10:11 AM
cmkwood's Avatar
No the only things on my cluster that work are temp and gas. No speedo or tack.
Old Mar 23, 2013 | 01:01 PM
No Big Whoop
The speedo is mechanical, all it needs is the cable going from the transmission to the back of the cluster and it needs to spin as the wheels move.
Get that going first.
The tach is electrical, you have a wiring problem and it could be a million things.
Old Mar 24, 2013 | 10:49 AM
cmkwood's Avatar
Solved the speed sensor just needed to be re done but the tach is next. thanks for your help.
Khrystin
Sep 15, 2018 12:25 PM
Channooo
Aug 12, 2009 01:50 PM
ugly rex
Jan 1, 2007 11:19 PM
k7q
18
Mar 25, 2006 04:44 PM
slow4dr
Dec 27, 2004 07:19 AM
