Clicking coming from injector fuel rail area
Old Mar 22, 2013 | 01:47 PM
94 sedan B16a's Avatar
Default Clicking coming from injector fuel rail area
Hey guys I have a 94 sedan with a 2000 b16a swap. The problem I'm having is that it's making a ticking sound by the injectors fuel rail area. Its not a constant tick but more like a morse code tickin. i have replaced plugs and wires and Ran fuel system injector cleaner. Also car is lackin power at all rpms especially 5500 and above. Won't go past 6500. But u can tell its cuttin power all the time. Fuel pressure is constant at 39 to 40 psi with a wallbro 255 kickin with no issuesAny ideas??
Old Mar 22, 2013 | 02:38 PM
EJ8_Man's Avatar
Default Re: Clicking coming from injector fuel rail area
Use an automotive stethoscope and find out what's making the ticking. If you don't have one, use a long screwdriver. Place the tip of the screw driver against the components making the noise, and the butt of the screwdriver in your ear.
Old Mar 22, 2013 | 03:15 PM
I used a medical stethascope(only thing I had handy) and I can't find it anywhere.. Put it on all the injectors all the spark plug wires and the fuel rail. Will a medical stethascope work for that? Also the tickin or the power loss doesn't occur when the car is cold. Only when the car warms up.
Old Mar 22, 2013 | 03:27 PM
EJ8_Man's Avatar
Originally Posted by 94 sedan B16a
Will a medical stethascope work for that? .
It doesn't sound like it worked considering you were not able to pin point the problem. It could be a bad injector, or valve lash. Get a tool that works and find the source of the tick
MRGRIM's Avatar
R.I.P. Mark
sounds like valve lash needs to be adjusted
would explain power loss and noise
Old Mar 22, 2013 | 04:26 PM
Ill see if i can get the valves adjusted. Is it hard to do yourself. Would u guys recommend a shop to do it
Old Mar 22, 2013 | 04:42 PM
B_Swapped93's Avatar
not hard you'll just need a few tools and a helms manual or study a good DIY. look in the FAQ sticky section on here
Old Mar 22, 2013 | 08:14 PM
Okay thanks. Ill keep ya posted. Hopefully gonna get it done tomorrow along with a few other things
Justin Thompson
Oct 15, 2018 12:46 PM
tempsohc
Aug 29, 2010 11:15 PM
hybrid_vtec
18
Feb 25, 2006 08:07 AM
freud
Feb 26, 2003 02:01 PM
b16awarrior
28
Sep 20, 2002 05:26 PM
