2005 civic new clutch
i'm at the point where i need a new clutch, ~130K miles.
while i'm in there, is it recommended to change the flywheel too? is it needed?
the car is just a regular commuter. will i gain anything from it?
also, what is out there that guys swap with?
thank you
thank you
Matt is right. you probably wont need a NEW one persay, but you will need to resurface it. dont forget that the break-in period for a new clutch/flywheel is 500-1000 miles of being EASY on it. try not to rev past 3,500rpm.
You dont "need" a new flywheel, but why not upgrade to a lighter one if your in there already? You would notice your car being a little more peppy, less weight on the crank every revolution.
B_Swapped93
Apr 4, 2013 06:30 PM
hondaracin24
Oct 11, 2004 03:25 PM
