trailing arm toe adjustement bolt/nut problem
while trying to drop my trailing arm down to put new bushing in, i had a hell of a time getting the toe adjustment bolt out. for a while, it just spun in place but eventually the nut caught and i was able to thread it all the way out and drop the rear arm...but now how will i get it back in? it seem the nut fell out of the track and i dont know how to reach it. will i need to cut from inside the car to get to that area or cut a part off the bottom somewhere? attached is the picture as to what i'm referring to.
thanks for any help you can give...i'm trying to get this thing ready for autocross which starts in less than a month
Unfortunately you have to cut a hole either from the inside or directly under in order to get to that nut and put it back.
Check the faq for a thread with pictures.
alscrx
12
Jun 13, 2009 05:26 PM
