eg braided fuel lines
Hey, I'm looking to upgrade the fuel lines on my hatch to -6 lines but I'm not sure what i need to get can anyone tell me what i need to convert them thanks in advance
^ just about to say.....google and I found a few articles on the subject.
http://civic-eg.com/viewtopic.php?t=7858
http://www.mnhondas.com/showthread.php?t=20577
http://floridahondacrew.com/showthread.php?t=22773
im losing fuel pressure so my tuner requested i use a larger line i dont know why this is so hard to understand a bunch of car use this setup with fuel cells im just using my stock tank????
I would think the same concept as mentioned above except longer hose. similar to a fuel cell setup, except replacing the main line with the braided steel....not sure on fittings you might need to go to the fuel tube i think its called but I don't see why you could not do it like this.
here is a photo of a setup posted by 4cylfiend
http://i646.photobucket.com/albums/u...0810001830.jpg
your plans to run it similar correct?
depends are u gonna run a new pump like maybe inline that would have an fittings to connect. any stock style pump even walboro you can not put an fittings on and would have to clamp the braided line and its not really a clean look but u can clamp it 0n
