just got a turbo ep3
So i got this 02 civic si with a greddy turbo kit. Needed some work and im giving her some tlc. Drives amazing and looking to get a tune soon but have to save some cash for the proper tune. ill take some pics soon so you guys can let me know what you think. Shes a running project so be kind lol
the ep3 came with a K24a4 block with a K20 head. I dont know anyything about the internals so that SUCKS, i really want to tear it a part and re ring and new bearings but dont have time right now. has a ep3 5 speed tranny with what feels like a stahe 3 clutch. K-sport dampers all around with front camber plates. skunk 2 lca in rear and beaks bar for that jdm look kids love lol. custon 3 inch straight pipe with apexi muffler, the down pipe needs one of those flex ***** to help with the exhaust rattle.
im running the stock greddy tune. Its programmed for the ep3 its even labled on the side of it.
anyone know what the fuel psi should be at? i feel like im running lean and idle has a misfire. Plugs are kind of white. so im thinking fuel pump or intake gasket is bad.
stock fuel pressure is 42 psi. A wideband isnt going to do you no good if you dont have a kpro.
I gave you the wrong fuel pressure. Stock pressure should be around 47-54 straight from the manual. I believe the pressure is a little bit higher because its a returnless fuel line.
well i did a compression test and the numbers are waayy lower then im use to seeing. They are 100 psi all the way across, i was expecting 150 psi at least. maybe rings are gone? any tips on how to tell if its rings or valves? the car burns no oil what so ever and during acceleration it picks up nice
Thats pretty low... Are you sure you did it right? Heres a link how its done. At least there no big differences.
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-compression-testing-your-engine-2917115/
https://honda-tech.com/forums/showthread.php?t=2917115
so if i drop a bit of oil and compression changes then the rings are bad?
compression stayed the same. First did it with wot and then wot/oil in cylinder.
What i did find was that my timing marks are slightly off. Time for new chain? Only rough at idle, but more like a misfire at idle.
K24a4/k20 head, so i use the k24 timing kit correct?
Yes you want the timing chain off a k24, perhaps new guides and tensioner.
