What transmission would be best for my 97 accord with an h22 swap
Old Mar 20, 2013 | 02:46 PM
Dopejr's Avatar
Default What transmission would be best for my 97 accord with an h22 swap
I have a 1997 honda accord with a h22A4 swap and I'm looking for a tranny with would be better and stronger any ideas on what would fit bests ?
Old Mar 20, 2013 | 07:53 PM
netopia's Avatar
Default Re: What transmission would be best for my 97 accord with an h22 swap
F22 tranny from an accord in my opinion
Old Mar 20, 2013 | 08:26 PM
DeadlockRiff's Avatar
If that H22A4 was boosted + lowered VTEC engagement I would agree with the F22 trans (from an Accord Wagon = 4.2FD, all other 4cyl Accords, 4.0 FD). Since you haven't said I would couple it with the original transmission, possibly swap the FD for a higher one if you favor a kick in accel in trade for cruising mpg and top speed. [MFactory sells em] The wide gears in the F22 trans will throw the H22 out of the hi-cam after a shift and just make it feel painfully sluggish.
Old Mar 21, 2013 | 12:09 PM
Dopejr's Avatar
So deadlockriff do you think I can get a gsr tranny and would you recommend it ?
Old Mar 21, 2013 | 02:13 PM
Well what are you looking for? The end speed of the gears between the H22 trans and the GSR trans is around 1-3.5mph differences. They're almost identical excluding the 5th. The GSRs 5th is a massive drop off for cruising. Now if you were dropping in a B16 trans (Ex: Del Sol VTEC) that would be a different story, which is tighter than both. At that point though you might be shifting almost as much as pulling, i.e. your average pulling time/amount might be less despite the gearing advantage.
GSR
3.23
1.9
1.36
1.034
0.787
4.400 FD
H22 trans (M2F4)
3.307
1.95
1.36
1.071
0.871
4.266 FD
Del Sol (Y21)
3.23
2.105
1.458
1.107
0.848
4.400 FD
Old Mar 21, 2013 | 06:40 PM
94EG8's Avatar
Seagull Management
A B-series tranny will not fit an Accord/Prelude/Odyssey chassis. You're effectively limited to an H/F-series trans.
Run the shortest geared transmission you can afford.
Old Mar 22, 2013 | 01:04 AM
balbowskie's Avatar
i could be wrong but i think a m2b4 lsd trans would bolt right up too
Terrj
Mar 2, 2010 09:49 AM
KleenL
Dec 20, 2008 05:40 AM
rollercosta123
Jan 29, 2006 07:48 AM
AGENT 99
Aug 5, 2004 07:38 PM
playAho
Oct 4, 2003 03:00 PM
