CLUTCH OR TRANS?????????
Old Mar 20, 2013 | 10:54 AM
91ACCORD4GLX's Avatar
Icon2 CLUTCH OR TRANS?????????
I have a problem I done a swap everthing was fine I pushed my clutch in and pit it in reverse and pulled out of my driveway in to the road I pushed the clutch in shifted to first and started to release the clutch heard a slight pop and didnt go no where and could shift it thru all gears with out pushing in the clutch
Please all info will help
Thank you
Old Mar 20, 2013 | 11:01 AM
brages's Avatar
Default Re: CLUTCH OR TRANS?????????
Axle not in all the way?
Old Mar 20, 2013 | 11:04 AM
Both axles are all the way in it feels like my chutch is stuck engaged
Old Mar 20, 2013 | 11:09 AM
jdowen2's Avatar
Make sure clutch master cylinder and slave cylinder are in good working order.
Old Mar 20, 2013 | 03:50 PM
brages's Avatar
If there's a problem with the clutch, I would expect it to feel excessively soft or firm.
Old Mar 23, 2013 | 07:46 AM
Lost Again's Avatar
Was this with the engine running? I'd check the cables for starters, you just did the swap, are you sure they are still on and on correctly.
OUTKAST1779
Jul 18, 2009 11:19 PM
Dre_559
May 28, 2009 08:23 PM
bpetruzzo
Nov 30, 2005 03:44 AM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
jdmteg95
Dec 17, 2002 03:52 AM
