Turbo'd DA's Post Your Downpipes!!
Old Mar 20, 2013 | 10:17 AM
rydinsolo's Avatar
Default Turbo'd DA's Post Your Downpipes!!
Well like the title states. Look to see how you guys have your downpipes. My current downpipe will not fit because of the front stock traction (subframe) under the radiator. I have thought about buying a innovative or nrg one but? Not sure if it will fit after that either
I currently have a hood exit up pipe. But am looking to put my bwr 3" vband down pipe and exhaust back on.
My current turbo setup is as follows
B16a obd1
Pakboost ram horn
Turbonetics 50trim with exhaust facing pass side
I am just trying to see what type of dp's you guys are running and some pictures of how they are routed
Old Mar 20, 2013 | 11:30 AM
DirtyDA9's Avatar
Default Re: Turbo'd DA's Post Your Downpipes!!
all b-series down pipes are the same. If you need room buy an aftermarket traction bar.
Old Mar 20, 2013 | 12:38 PM
rydinsolo's Avatar
Not all b series dp's are the same...it has more to do which direction your turbo is sitting and what type of manifold you have..i had a different style dp i got from a friend that worked on the car for awhile until i bought the bwr vband dp. And now i swapped the motor turbo setup and hydro trans into the da.
Any one else??
Id like to see some custom downpipes or up pipes
Old Mar 20, 2013 | 03:19 PM
DirtyDA9's Avatar
Sorry I wasnt so thorough, depending on direction of turbo, or top/bottom mount, 5-bolt/4-bolt, they are the same.
slowb20civic
Feb 23, 2006 08:03 PM
BigC-ivic
Oct 7, 2004 05:04 AM
MarkAngelo
Sep 27, 2004 08:53 AM
X2BOARD
Jun 27, 2003 07:00 AM
