So.. What exhausts are the same?
Old Mar 20, 2013 | 09:29 AM
john159753's Avatar
Default So.. What exhausts are the same?
I just got a GSR longblock for my 00 Civic SI. Now i know the intake manifold is boltup is different between the B16A2 and the B18C. But what about the exhaust?
(For teh Lulz)
I've heard they are the same.. If that's true do i just get a header for a 00 Civic?
If the bolt pattern on the B18C head is different than that of the B16A2, what in the world do i get? Do they make Headers that fit a B18C and the Civic at the same time?
Old Mar 20, 2013 | 10:07 AM
toto98coupe's Avatar
Default Re: So.. What exhausts are the same?
The gsr head has a different bolt pattern on the intake side
Exhaust is the same as si and type r
Old Mar 20, 2013 | 10:30 AM
Jdm_Ej8_Sedan's Avatar
Get a header for the b18c because it will bolt up directly but you might have to make alittle modification down by the cat and support parts of the header so it all flows correctly. Like maybe a small flex pipe to the cat and might have to weld the bracket that is used for support on the header (if has one) to the chassis. Just look into it alittle more, do some good research.
Old Mar 20, 2013 | 10:36 AM
speedooo's Avatar
The bolt pattern for the exhaust manifold is identical for all b series heads. The difference is that the 1.8 motors have a taller deck; a b16 header may not clear the oil pan.
Old Mar 20, 2013 | 10:49 AM
eghatch9295's Avatar
Stancetard Hate Monger
yep. a bolt on affair with your current parts.
Old Mar 20, 2013 | 12:07 PM
john159753's Avatar
Thanks for all the responses guys. So since in not in the immediate market to buy a Header, i can run my b18c (i bought it from hmotors, so it came with a downpipe ) stock exhaust manifold, right up to my OEM cat?
LastGenEK
Oct 26, 2007 09:55 AM
IowayRUlz
Dec 21, 2006 02:17 PM
Honduh Chicken
Apr 19, 2005 07:51 PM
gulftiresinc
Sep 14, 2004 03:26 AM
Slick GS-R
May 4, 2002 10:34 AM
