b series cable internals in hydro tranny
I have a hydrolic gsr and si tranny. Dont really know what is wrong with the gsr transmission but the si transmissions reverse is out. I also have a b series cable transmission that is good. Can I use the cable transmission parts in the hydrolic transmission?
It depends on which cable trans it is. If it's a YS1 parts interchange, although if it's an LS tranny you wont be able to use many parts unless you swap everything into the hydro case.
civickiller
Apr 7, 2006 03:15 AM
