Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
tryimg to install a rmanufactured ps pump, and the plastic fitting for hose....
Old Mar 19, 2013 | 01:49 PM
quarterroy13's Avatar
Icon6 tryimg to install a rmanufactured ps pump, and the plastic fitting for hose....
i am trying to install a new ps pump in oreder to save about 300$ per honda dealership estimates. everything was going well, untill after installing pump, when i tried to attatch the plastic fitting that attatches to the top right of pump allowing the hose to clamp to it, the hole on pump is about 1 or 2 mm's too small for the existing fitting.... there is NO auto parts store around who has this part, and even if, (as told by a honda mechanic) a replacement will be the same size... is there anything i can do, short of sawing and filing off the large end of the fitting? i haven't attempted this for obvious reason's, but i have no car now, and becoming hopeless, please help!!!!
Old Mar 21, 2013 | 03:47 PM
swordofdoom's Avatar
Default Re: tryimg to install a rmanufactured ps pump, and the plastic fitting for hose....
You can either find a reducer that works, or your pump is not the correct one for your car year.
Old Mar 22, 2013 | 11:50 AM
BLKFLSH's Avatar
I would return that pump, and get the right one. You don't want the hose to leak.
Jayman_Gsr
Aug 8, 2013 05:26 PM
o2flow.net
Jan 11, 2006 11:48 AM
shawn_crx
Mar 6, 2005 12:14 PM
StupidSlowRSX
10
May 3, 2004 02:34 PM
