Rev Limiter Early Actuation
Old Mar 19, 2013 | 09:09 AM
KidAccord's Avatar
Default Rev Limiter Early Actuation
OK so i have a 94 Honda Accord Ex (f22b1) the engine was just rebuilt along with the transmission, and only mods i have done to it are cold air intake and different exhaust.
So the problem is it hits the rev limiter at 5,000-5,500 and its not putting out any codes.
only thing i can think of that we haven't touched on the car is ECU,Catalytic converter and fuel pump but im not sure what to check for.
this seems to be a common problem with these accords so any advice?
Old Mar 19, 2013 | 09:45 AM
92 civic ex 4dr's Avatar
Automatic or manual?
Check your TPS and MAP sensors. Make sure they are good and properly cleaned/installed
Posted from Honda-tech.com App for Android
Old Mar 20, 2013 | 05:47 PM
KidAccord's Avatar
Default Re: Rev Limiter Early Actuation
its a manual
and ill check them out after work tomoorw but im prity sure the MAP sensor is good
Old Mar 21, 2013 | 04:28 AM
Fitz Williams's Avatar
10 Year Member
Mine does the same thing. But the problem is the tach, not the rev limiter. Check your revs against your highway speed and see if that might be your issue.
According to my tach/speedo I can do over 90 in 4th (auto) at 3000 rpms. No way.
Old Mar 21, 2013 | 05:51 PM
KidAccord's Avatar
good point i thought about that but didnt really check because my speedometer dosent work but the speedsensor is fine its just the dash so it could be something like that
Elmorro_jo3
Dec 9, 2014 03:45 PM
o5hitbryan
Dec 16, 2008 11:39 PM
trooper0641
24
Jan 13, 2006 02:34 PM
jaythor
Jul 8, 2005 04:18 PM
Jstue
Dec 25, 2003 09:41 AM
