Transmission & Drivetrain Gearboxes, Differentials, Clutches
Cable S1 B16 Tranny questions
Old Mar 18, 2013 | 06:02 PM
RanCRX's Avatar
Icon2 Cable S1 B16 Tranny questions
Ok, well the input shaft bearing got stuck in the upper case, I tried hammering the sides of the case etc. So I took a pry bar and hammer and whapped it out, but the bearing ball(s) fell outof the center assembly. I put all the ball(s) back into the bearing successfully but I'm kinda iffy about it. Can I reuse it? I can't push the ball(s)out by hand but I can hammer it out. I'm not able to put back on the case cause the bearing gets stuck on the upper case leaving a gap, so i have to keep prying it out. Maybe needs some oil lube? Any ideas?
Also, is there a tutorial of how to manually slide the synchro sleeves using the forks into gear? I can onlly slide 3rd and 4th together but 1st, 2nd and 5th are not going in. Any youtube vids?
If I were to buy synchros and bearings etc for this transmission would any 90 91 integra tranny work? Of course besides the gears.
Any help appreciated, hopefully I explained it well enough.
Old Mar 19, 2013 | 10:21 AM
Aquafina's Avatar
Default Re: Cable S1 B16 Tranny questions
Replace it.
The sliders have three pairs of two larger teeth that line up with larger spaces on the hub.
Yes, bearings, synchros, seals for 90-91 Integra.
Old Mar 19, 2013 | 07:38 PM
RanCRX's Avatar
Cool thanks for the info. Will replace. If anyone can pass info I checked a few online acura websites and they say the bearing is discontinued. Any better websites on the acura side? Like majestic honda. Let me know
Old Mar 19, 2013 | 08:15 PM
RanCRX's Avatar
91004-PS1-003 part #. All the places says this bearing is discontinued. Some say may have been discontinued. Any help appreciated
Old Mar 19, 2013 | 10:56 PM
Runnerdown's Avatar
Try contacting synchrotech, its possible they have one or can source it.
thedudefromjerz
Aug 8, 2008 11:58 AM
AJxr
Feb 7, 2006 07:59 PM
hybrid1990crx
Feb 20, 2005 05:58 AM
Wopsicle69
Jan 6, 2005 04:44 PM
