can alternator go bad and no dummy light?
Old Mar 18, 2013 | 01:30 PM
wasp9166's Avatar
Default can alternator go bad and no dummy light?
in the past i've gotten the batt light on dash when alt craps out
today, driving home from gym, radio starts going off and on by itself
usually this is a tell tale sign
so ,i pop hood and i have 11 volts at batt with engine running, should be 14, also 11 volts with engine off
but no dash light
no codes
Old Mar 18, 2013 | 02:39 PM
ef_cowboy's Avatar
Default Re: can alternator go bad and no dummy light?
Maybe that bulbs disconnected or burnt out. I'd still replace the alt. because if the low voltage. Also have the battery tested to make sure it's the problem or the battery hasn't been worked to hard
Old Mar 18, 2013 | 02:51 PM
wasp9166's Avatar
new diehard 6 months ago or so
went with a new napa, f the pos at advance and autozone
Old Mar 18, 2013 | 02:54 PM
ef_cowboy's Avatar
I'd check it to be safe. A lot of times a bad alternator will kill a battery from over working it
Old Mar 18, 2013 | 03:13 PM
wasp9166's Avatar
well, with 11 volts when engine is off is good no?
what ya mean, take it somewhere and have em check it?
Old Mar 18, 2013 | 03:33 PM
Tyson's Avatar
ive had to replace a bad alternator without a charge warning light go on.
it happens.
Old Mar 18, 2013 | 04:53 PM
ef_cowboy's Avatar
11 volts is ok but I'd charge it at least.should be 12v off.my battery is 12.75 volts off.. And ya autozone,pepboys or places like that can check it for free.
Old Mar 18, 2013 | 05:17 PM
DAP91Si's Avatar
I had an alternator that would intermittently go bad with no warning light. Tach sputtered, lights were really dim and wipers barely moved. I put off changing it and the constant deep discharge of my battery significantly shortened its life.
Old Mar 19, 2013 | 03:14 AM
wasp9166's Avatar
yeah, good idea, i'll pick up a schumacher from advance, had an old charger but it crapped the bed
Old Mar 19, 2013 | 06:28 AM
wasp9166's Avatar
got this
http://www.ebay.com/itm/Schumacher-SSC-1500A-Ship-n-Shore-SpeedCharge-Charger-/111029233513?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d9dba769&vxp=mtr
batt was 35% .............
payed $75 at advance cuz couldn't wait, oh well
Old Mar 20, 2013 | 11:57 AM
wasp9166's Avatar
mmmmmmmm, this may be normal, but i've never noticed it before
batt charged to 100%, new napa alt
when i start the car i have 12.5 v at batt
after about a minute at idle, the idle will drop down and i'll have 14.3v at batt after it drops
almost like something turned on
does the alt only cycle when it's needed?
i thought it was continuous output............
perhaps the volt reg is shutting it on and off since the batt is so well charged?
Old Mar 22, 2013 | 03:08 AM
wasp9166's Avatar
bueller? anyone?
Old Mar 22, 2013 | 09:37 AM
Tyson's Avatar
normal. its what all fuel injected cars do.
Old Mar 24, 2013 | 03:12 AM
wasp9166's Avatar
cool, learn something everyday,ty
what's the fuel injection have to do with it?
CivicSD
Oct 25, 2010 09:24 AM
Str8JDMCRX
Oct 26, 2009 05:44 PM
Bunny
May 24, 2009 01:16 PM
lrcrx90
Jul 21, 2007 01:20 PM
