***HELP***Eg si doesn't start, drove it this morning now has no power at all
Old Mar 18, 2013 | 12:41 PM
ef_hatchback's Avatar
Default ***HELP***Eg si doesn't start, drove it this morning now has no power at all
I drove my friends eg si hatchback in town this morning, running perfect. Then I got ready to leave the house after 5 hours I go to leave and put the key in the ignition and go to start it, once I turned the key over there was absolutly no power, stereo didn't even come on. I've checked the fuses, changed ecus, changed the main relay, check all grounds, battery still has power it self. Weird cause it ran and started perfect this morning.
Old Mar 18, 2013 | 12:44 PM
Emeraldbomber's Avatar
Default Re: ***HELP***Eg si doesn't start, drove it this morning now has no power at all
What ecu did you change in it to test it?
Old Mar 18, 2013 | 01:49 PM
Put a p28 from a running car. Nothing still.
Old Mar 18, 2013 | 06:13 PM
Mr. H1TMAN's Avatar
Hot wire the starter? Does it crank at least?
jdmpeteek9
Aug 15, 2013 07:47 PM
CRXguy_88
Feb 22, 2012 07:49 PM
yanksox
Nov 28, 2010 08:06 AM
EF927
Dec 30, 2009 05:05 PM
