B20 vtec help
Old Mar 18, 2013 | 07:20 AM
Brandon_ek's Avatar
Default B20 vtec help
Ok so I recently did a swap in my 99 sir , sir head b20b bottom but now my cars puffing blue smoke and burning large oil cyl#1 60psi now I determined. It's the rings , so I'm planning on buying a 100% healthy motor from teknotik in Toronto but I'm stock on if I should build it or leave it stock
Ac is deleted
Here's my bolt ons I have:
Aem 3" cai
Blackworks intake manifold
Hytech big tube headers*
Str throttle body
Hi flow cat 2.25*
P28 b20 vtec basemap*
Slim fan and rad*
Greddy catch can setup ported to valve cover
Blox coolant overflow tank
Yonaka stage3 clutch
Mishimoto fan switch*
Type r oil pump
Type r water pump
Old Mar 18, 2013 | 07:37 AM
slowDB7's Avatar
Default Re: B20 vtec help
leave the new engine stock, and rebuild the one thats in now
Old Mar 18, 2013 | 07:56 AM
Brandon_ek's Avatar
The other bottom is getting scraped it was bad from day 1 we determined , I'm only keeping my head and buying another b20b bottom
Old Mar 18, 2013 | 08:51 AM
B_Swapped93's Avatar
What trans do you have ? might be a good time to get a new one while the engine is out again(unless you used you'r SiR one).
Old Mar 18, 2013 | 12:32 PM
Brandon_ek's Avatar
It's the sir trans mint no grinds
FREDDY_OTL
Aug 26, 2014 06:29 PM
vyrus
10
Feb 15, 2012 09:19 AM
Charltons_Trix
Mar 25, 2008 06:17 PM
EatMyExaUst
Jun 10, 2007 10:13 AM
kem0s
Jul 21, 2002 01:24 PM
