I can use a D16z6 Throttle Body on my B16a2 - EM1????
should be able to. You just need to make sure you've got working tps, map, iacv, fitv(if applicable) setup. some setups have some parts mounted on tb, others on IM. get the right combination and it'll work.
should be fine. from what i have read you will be ok how come you decided to go with this TB and not onther b series?
You'll lose 4mm in size so you won't see any performace gain(i know that's not why you're swapping it) but you mentinoned it feld boggy/slow. Why not pick up a S2:alpha 68MM TB for 120.00 or so
Well i have Bad Idle and in three months I had to change the TPS sensor 3 times, and I have a bad performance and poor mileage i think my Throttle Body dont work properly and for that i have all this problems. and now again i haven a P0122 code and i dont want buy another tps again, i prefer buy a TB with all this sensors, understand??
You can get that code from a short in the wiring for the tps sensor plug and if the plug is dirty and not contacting well.
Have you done any voltage test to the tps plug?
Were you properly calibrating them as well?
atarigamer01
Jul 1, 2008 07:29 AM
civic_tuned
Apr 20, 2005 04:11 PM
KevronsEG
Jan 31, 2002 05:23 PM
