Swapping Engines
Would I be able to swap a 5th gen DX motor into a 4th gen si if I change the manifolds and wiring and use the si tranny and drive axels? I need to make my winter car run and the si engine has been overheated and has over 200,000 miles, the DX ran fine and only had 80,000 miles.
yes
u gotta use ur 4G engine mounts..... use the 5G exhaust manifold, use ur SI intake manifold, use ur stock harness, engine, shift linkage, basically the only thing u need its the block+head+exhaust manifold (unless u got headers)... the rest its the same thing ur car has...... ur SI has "108 stock" and the DX has 106... dont think u will be loosing a lot of power....
firstgenrex
Oct 6, 2003 05:47 PM
simike
Aug 13, 2002 02:50 PM
LsTurbo91
Jul 2, 2002 06:14 PM
