GM ITR DC2 center caps k20a2 timing cover chain ac compresor ap1 starter gsr MISC
MOST STUFF on topic has sold so heres the updated little stuff i have left
hasport ekk1 rear mount $60shipped
tsx 04-05 power steering pump $50shipped
k20z1 timing cover, chain, tensioner etc and misc screws sensors with it $80shipped also have a k20a2 with an extra cover with drilled hole to make it fit k20z1 and k20a2 now
k20a2 ac compessor $100shipped will include lower bracket or reduce $20 off if you dont need it with it
05 tsx oil pump and beat up oil pan that has a small hole from motor being dragged but can probably be easily mig welded to patch it up or so to use $75shipped for all of that
AP1 s2000 starter $60shipped
silver s2000 ap1 side brackets $30shipped
AP1 s2k engine harness with vtec solenoid since i dont need it anyways SOLDD
Integra type R itr gunmetal center caps (one is bleeding in the red a little) $50shipped
94-01 integra rear T bracket $40shipped
civic 96-00 driver side and top tranny bracket $40shipped together
99-00 civic si ex p2p p2t ecu $60shipped for both or $40shipped each
k24a2 and k20z1 sepentine tensioner $30shipped each
k20a2 oem header $30shipped
inbox me if interested
i also have the remaining block parts like water pump and oil pump and chains. im open to offersparts are located in arlington texas. paypal only and with members that arent new with zero posts..not risking to get scammed sorry..
CTRbOy
Jun 16, 2011 07:24 PM
951dc5
Nov 22, 2005 01:07 PM
FS: B vtec distributor, timing belt cover, wire harness, oil & water pump, PS & AC pump & bracket, I
slofu
Sep 1, 2004 11:22 AM
