NV FS: '00 Civic Si EM1 | JDM-R | Reliable DD
oh yeah - the antenna is stuck in that position. I never listen to the radio so I never bothered to fix it or block it off...shrug.
bump
Brake fluid and Clutch hydro fluid flushed w/ ATE Super Blue 6/12 as well as new NGK BKR7E plugs (I believe 1 step? colder than stock) and NGK blue spark plug wires.
I have bunch of other random stuff like extra oil filters etc that will come w/ the car as well
No holes in the trunk, I don't think the car came w/ the wing. I always thought the wing was included on the Si trim but apparently not?
edit: just checked, the VIN sticker matches, so it's the original trunk. So guess the wing was optional then.
Personally I like wingless Si's anyway. ITR's too. Too much damn attention from the po
U can see the trunk pretty well (click) HERE
Get a retrofit done professionally w/ the mentioned parts and new OEM headlights, then get them clear bra'ed, then come tell me $500 is too much. Haters gonna hate, ballers gonna ball bro.
Kthxbye, thx for the bump
Neptune RTP so OBD1 conversion harness. But it's all wired for OBD2 so you can pass your state's inspection w/o throwing codes. Just plug in the stock b16 ecu and granny shift. I just pull into the station, swap ecu's, let the guy do his thing, then swap back and drive away haha. Some states are a bit more strict than mine tho.
bump - more pics added of HIDs, hytech exhaust
also have NIB PWJDM rear LCA's
you can see the rear suspension was bleh, so I was planning on a full change...
eluder33
Jan 31, 2006 06:14 AM
haha !
Totally turned way too early backing out after parking right next to a curb haha. whoops!
