Misfire Codes - seems to run fine
Old Mar 17, 2013 | 12:35 PM
themiz816's Avatar
Default Misfire Codes - seems to run fine
I have a 98 accord 4cyl vtec. Ive been working on it a bunch lately because of stalling/idle issues. I had a mechanic replace a oil pressure switch this last week and everything seems to be fine since then. Although the issue I was having was pretty random and unpredictable.
Last night the check engine light came on. It was p0304 and p1399. Cylinder 4 misfire and random cyliner misfire. I never felt the car sputter or anything. It may be idling a little bit hard, but it never hesitated or stalled.
1. Is it common for misfire codes to pop up without "feeling" the misfiring?
2. Any good ideas what to attack? Already done plugs/wires/iacv/egr/cleaned throttle body.
Old Mar 20, 2013 | 08:41 PM
go-part's Avatar
Default Re: Misfire Codes - seems to run fine
Have you checked/replaced the distributor yet?
Misfires on a certain or all cylinders are usually an ignition issue.
Old Mar 20, 2013 | 11:18 PM
holmesnmanny's Avatar
Can you take a very good picture of your spark plugs and post it ? Make sure to mark which plugs go to which cylinders. I think in this situation the spark plugs might be key.
Stang69
Jul 1, 2019 04:07 AM
Da9austinRacing
Nov 29, 2010 09:36 AM
Lewsears
Mar 20, 2010 09:25 AM
JDM_SOHC
26
Jun 28, 2006 11:55 AM
hondaowner
Apr 6, 2004 04:42 AM
