Opinions on next step
Old Mar 16, 2013 | 08:36 PM
fitbkeco's Avatar
Default Opinions on next step
So here's what I came up with so far my car still fires and dies immediatly so I check my fuel pressure And I'm only getting 10-15lbs would my main relay cause this or fuel pressure regulator I ripped one off a eg today it's not the same but I figured it couldn't hurt to try it (just doesn't bend at 90) I have my main relay out and the pins don't look cracked but they do look almost ?burnt? so should I try to solder them? Any one have an idea?
Old Mar 16, 2013 | 09:28 PM
fitbkeco's Avatar
Default Re: Opinions on next step
So I check my main relay and it clicks one when the car fires and then click again and the car dies so I'm thinking resolder won't help right?
Old Mar 16, 2013 | 09:29 PM
Pistonman's Avatar
Are you checking the pressure before or after the filter?
If after, maybe the filter is plugged.
If before, check voltage at the pump.
Old Mar 16, 2013 | 09:38 PM
fitbkeco's Avatar
I changed the filter and I checked after
fitbkeco's Avatar
If I'm not getting enough power to the pump what would be causing that
Old Mar 16, 2013 | 09:52 PM
odz-fab's Avatar
the main relays can be problomatic at times. the main relay also supplies power to the ecu.. you may try a new relay from autoparts... if it works you know your problem and can always return it and source a good used one. if its just the pump you can wire the pump directly to a toggle switch to help eliminate variables.
Old Mar 16, 2013 | 09:56 PM
Pistonman's Avatar
Bad wire, bad connection, corrosion... too much resistance...
If you are careful you could put a test wire between battery and pump with a fuse in it, and check pressure.. if good that would eliminate the pump.
Old Mar 18, 2013 | 11:40 PM
fitbkeco's Avatar
so i changed out my main relay and still the same s*** happens itll rev to 1000-1500 rpm then die.. would it be worth replacing the fuel pump really dont waant to waste the money if i dont need to. the car has sat for 2 years before i got ahold of it so i heard that fuel pumps can go bad after sitting for so long... any one else ever hear that?
Old Mar 19, 2013 | 06:16 AM
Creator's Avatar
Well, if your fuel pressure is still low, it's pretty much gotta be the pump. Will the car stay running longer if you give it a little gas (throttle cable, or gas pedal)?
Replacing the pump in these cars is not a fun task.
Old Mar 19, 2013 | 08:19 AM
fitbkeco's Avatar
Nah if I step on the pedal nothing happens the car just dies
Old Mar 19, 2013 | 09:02 PM
fitbkeco's Avatar
can be my ecu? when i turn my car on the ecu blinks one time a red a light then it goes off and never comes back on?
Old Mar 19, 2013 | 09:14 PM
jdm_rb20's Avatar
Creator, please remember his original question also mentioned the FPR. The FPR is easily forgotten, so I just wanted to mention that it can cause low pressure.
If the fuel pressure regulator goes bad, it can either build too much pressure OR release too much gas which will lower the fuel pressure.
I forget the troubleshooting steps for the FPR, but you can:
remove the fuel input line at the engine and turn the key to prime. It should have a strong stream.
Also, removing the vacuum line from the fpr may result in an increase or decrease in fuel pressure...i cant remember which. If yours has a vacuum line on the FPR, remove it and see if you can rev a little higher.
Old Mar 19, 2013 | 09:20 PM
fitbkeco's Avatar
i just replaced both the regulator and the main relay with no change in what the car does... the last thing for fuel is the pump which im gonna get tom. i also heard to check my ecu.. so when i turned the car it would blink red one time and then wouldnt happen again. no light would be on at all
Old Mar 19, 2013 | 11:18 PM
Son2BEHO's Avatar
Maybe the filter sock on the fuel pump is clogged on mine I had 35psi regulator plugges in and 45 with vaccum line off its dpfi
Old Mar 20, 2013 | 08:34 PM
fitbkeco's Avatar
the fliter looked fine when i pulled it off and the bottom of the tank has like no dirt in it.. i just order a walbro 255 fuel pump today so hopefully that makes my car run
Old Mar 22, 2013 | 05:04 PM
jdm_rb20's Avatar
The factory FPR is designed to maintain XXpsi fuel pressure when the factory fuel pump applies its XX flowrate. If you increase the flowrate without adjusting the Fuel Pressure (via an adjustable FPR), you will be running super rich. You will definitely have no problem getting fuel. Upgraded fuel pumps also require upgraded FPR's.
Old Mar 22, 2013 | 10:56 PM
fitbkeco's Avatar
Yeah I ordered a new fpr to I just figured since the tank was out if I ever boost it I'm gonna need a better pump so ill just do the job once and save time
fitbkeco's Avatar
I got to get it running first tho lol
Old Mar 22, 2013 | 11:12 PM
fitbkeco's Avatar
has any one ever used blox fpr?
Old Mar 23, 2013 | 05:19 PM
jdm_rb20's Avatar
I'm rethinking your original post after reading the other info you have described later. Does your car maintain an idle? Or does it only fire for the 1second that your key is turning the starter?
If so, maybe the ign switch is not making a good connection to the ACC+ wire. After the starter starts spinning the engine, the ACC+ maintains voltage to the ECU, fuel pump, probably the relay (that may be turning off because of inconsistant ACC+ power??)??
Old Mar 23, 2013 | 07:02 PM
fitbkeco's Avatar
Where is that located at? it only fires up for a second then dies on me.. But would the car still run spraying starter fluid down it if it was that wire
Old Mar 23, 2013 | 07:37 PM
jdm_rb20's Avatar
I don't know the specific power sources for the ECU, distributor/spark, and fuel pump/injectors.
The ACC+ originates from the back of the ignition switch. It is supposed to be supplied with 12v+ when the key is in that position.
If you can get a wiring diagram, you just stated that starting fluid keeps it running...so you know this:
1)It IS sparking...so check the wiring diagram to find the power source of the ignition system...THEY ARE WORKING. Rule them out. (I would anyway...)
2) Use a voltage-meter to measure the voltage of the fuel pump's 12v+ wire WHILE someone else is cranking it. Measure this voltage using the CHASSIS as the ground, and then repeat the test using the fuel pump's NEG- ground wire as the ground. Should definitely get 12v+ during and after key-crank when using the chassis ground. If you don't have roughly the same voltage using the fuel pump's NEG- ground wire, then clean/re-ground the ground wire and try again.
3) Where are you checking fuel pressure? between pump and fuel filter? between fuel filter and injectors?? Between injectors and fpr?? or after FPR?? Easiest test for a weak pump is to pull the fuel filter off and prime the pump by turning on the key. If the stream is weak, then there is definitely an issue with the pump or the pumps wiring or fuel line.
Old Mar 24, 2013 | 07:47 AM
blk91crx22's Avatar
When I sent you that pm it was for troubleshooting your fuel pump and since you have low fuel pressure it most likely will be the fuel pump, or clogged fuel filter
Old Mar 24, 2013 | 03:47 PM
fitbkeco's Avatar
Well I bought a 255 fuel pump so I'm gonna throw it in tom when I get on liberty so I let you guys know if it fires up.... Crossing my fingers it does
Old Mar 25, 2013 | 10:57 PM
fitbkeco's Avatar
Well Installed the fuel pump and got the same ****.... I'm lost what could cause this electrically
