Need help hole in block
Old Mar 16, 2013 | 11:16 AM
Skatnshawn's Avatar
Default Need help hole in block
I have an f22b2 I was removing bracket for exhaust manifold and instead of bolt coming out I took off a chunk of block, now there's a hole, whats the best way to fix it? Can I use jb weld? Do I have to have it professionally welded?
Old Mar 16, 2013 | 01:38 PM
Skatnshawn's Avatar
Default Re: Need help hole in block
Anybody know?
Old Mar 16, 2013 | 01:50 PM
Skatnshawn's Avatar
Ok no replies but search engine finally pulled up something useful so no jb weld for that area gotta price getting somebody to weld it, anybody know why block would have been weakened there to begin with?
Old Mar 16, 2013 | 01:57 PM
92 civic ex 4dr's Avatar
You have to be a little more patient around here. You won't always get a reply right away or even in 12 hours. People have kids, jobs, and lives.
No you can't use jb weld on a block. If you can find someone who can cleanly and effectively weld cast aluminum then by all means save your self from buying a block. If not then your looking for an engine or block.
The only thing i can think of as to why it would break the block without first breaking the bolt (happened to me), is it was either heat welded to the block and the amount of torque applied to the bolt by you trying to remove it caused the weakest point in the casting to break, or someone else used jb weld or something else on the threads possibly to hold it in
Posted from Honda-tech.com App for Android
Old Mar 17, 2013 | 06:58 AM
Lost Again's Avatar
Can you post a pic.....did a chunck come off in such a way that there really is a hole in the block.....or did a piece come off around the bolt?
I think I'm just as confused as "92" is about how this happened??????
Old Mar 17, 2013 | 07:25 AM
GhostAccord's Avatar
If you came across the hole while you were taking off the exhaust manifold. Wouldn't that be a hole in the head and not the block?
You have to post pictures as to what has happened, your explanation kind of leaves large holes to the imagination....
Old Mar 17, 2013 | 12:29 PM
Skatnshawn's Avatar
I will try to post pic but not sure how from phone, on f22b2 where the stock exhaust manifold has a hanger on the block I tried to take out bolt and a chunk of block came off leaving a hole all the way through
Old Mar 17, 2013 | 12:37 PM
In that case if it is a hole that has compromised the crank case/block. I would say it would be cheaper just to swap in a good condition used long block. Then again, that all depends on the labour involved in order to get a welder in there to fix it. There are some good welders out there that may be able to weld it in the car.... However aluminum is a very tricky and stubborn material to weld. It has to be super clean, oil free and both pre and post heated to achieve a good solid weld.
Then again you could get some guy who will do it and cold weld it right over the oil and dirt and call it a day.... Then you are destined to go through the same issue again within a matter of time.
Old Mar 17, 2013 | 12:49 PM
Skatnshawn's Avatar
Skatnshawn's Avatar
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://pic2.pbsrc.com/flash/rss_slideshow.swf" flashvars="rssFeed=http:%2F%2Ffeed1290.photobucket .com%2Falbums%2Fb522%2Fskatrshawn%2Ffeed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="javascript:void(0);" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s1290.beta.photobucket.com/user/skatrshawn/library/" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_viewall.gif" style="border:none;" alt="skatrshawn's album on Photobucket" /></a></div>
Old Mar 17, 2013 | 12:56 PM
With Photobucket you want to copy and paste the Photobucket "IMG code" option in here.
Should look like {IMG}http://photobucket.blahbla.jpg{/IMG}
Old Mar 17, 2013 | 05:54 PM
Skatnshawn's Avatar
Skatnshawn's Avatar
http://s1290.beta.photobucket.com/us...shawn/library/
Old Mar 18, 2013 | 04:45 PM
Lost Again's Avatar
Holy crap.....that sucker is gone.
Looks really clean and I see a chain....guess you are already pulling the engine...but then again as clean as that block is,,,,,,there has to be more to this story?
Old Mar 23, 2013 | 11:55 AM
Skatnshawn's Avatar
Not much more to it, had an open end wrench on it and it broke off like that, salvage yards kinda screwed me with this motor
Old Mar 23, 2013 | 11:37 PM
holmesnmanny's Avatar
It looks like it was painted. I wonder if that thing was already broke off...someone jb welded it...and then painted it...or did you paint it ?
Old Mar 24, 2013 | 12:25 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
What the........
mudpuppy4life
May 1, 2011 10:15 PM
x91crxsix
Jul 28, 2006 10:42 AM
Turbo-Honda
Welding / Fabrication
Apr 7, 2006 08:29 PM
VTEC Sol
Jan 28, 2005 07:26 PM
-iLLuZioN-B18C1
Aug 4, 2004 06:19 AM
