94 accord ex wont crank plz help
Old Mar 15, 2013 | 02:28 PM
toni_the_kid's Avatar
Default 94 accord ex wont crank plz help
i have a 94 ex accord that has 2200 miles on the rebuild which included rod bearings, rings, water pump, timing belt, all new gaskets, real main seal, valve job on head. new distributor pulgs wires rotor and cap etc. it ran fine for the 2200 but the other day it wouldnt crank. it turned over but wouldnt start.i checked my spark plugs and there covered in fuel. i googled my problem with not much help at all. i rechecked timing it was fine checked spark it had plenty. it had 150 compression in all for cylinders. i dont know what else to check. if some one can help me or point me in the right direction i thank u in advance. this is my gfs car and i have 3 kids so i need it running. plz help
Old Mar 15, 2013 | 05:24 PM
ReaperMan's Avatar
Default Re: 94 accord ex wont crank plz help
leaking or stuck injectors. what you should do is disable the fuel and let the spark burn the fuel in the cylinders then try to start it again. if somehow it got flooded it is never going to start
Old Mar 15, 2013 | 05:25 PM
ReaperMan's Avatar
oh and dumping raw fuel into the catalyst converter is a good way to ruin it in less then 30minutes
Old Mar 15, 2013 | 06:04 PM
ok ill do that tomorrow. how would disable the fuel? unplugging the pump fuse and just keep trying to turn it over till it burns it all up?
Posted from Honda-tech.com App for Android
Old Mar 15, 2013 | 06:46 PM
94H22CD7's Avatar
That'd be the way to do it. If you just unplug the injectors it'll make the pump run and push fuel through.
Old Mar 15, 2013 | 07:02 PM
Ok ill try them tomorrow when I get time. Thank y'all so much
Old Mar 15, 2013 | 07:09 PM
ReaperMan's Avatar
np good luck
mista merc
Jul 9, 2015 02:52 PM
1994preludevtec
Jul 14, 2011 10:43 AM
CD5H23ACAVO
Apr 11, 2011 07:06 PM
z31jaime
Aug 3, 2008 05:29 AM
phateless
Oct 19, 2004 09:09 AM
