Honda CR-V & Element 2WD & 4WD Element & CR-V
transmission stays on first gear only
Old Mar 15, 2013 | 06:12 AM
josebakasi's Avatar
Default transmission stays on first gear only
the "D" light on my 04 civic was blinking and runs bad, from scan tool it shows shift solenoid A. So I replaced the whole set (A & B). Now the blink was gone but the tranny stays on first gear only. Need help please guys give info.
Old Mar 15, 2013 | 07:24 AM
Kevin Lu's Avatar
Default Re: transmission stays on first gear only
Hi there, fellow Filipino. Methinks you've posted on the wrong section. This is the CR-V section of the forum.
Have you checked the usual culprits? ATF levels okay? No more trouble codes from your scan gauge? I had a similar problem with our 98 CRV a few weeks back and ended up getting a replacement transmission from Banawe (area of my city that has loads of auto parts stores)
nalei
Transmission & Drivetrain
Oct 11, 2016 11:18 PM
Thatboyslim
Oct 2, 2015 10:18 AM
hunda91
13
Aug 13, 2015 08:04 AM
Integra9000
Jan 25, 2007 12:27 PM
