S300 NEED help with wideband analog input, all i see in volts
Old Mar 14, 2013 | 04:16 PM
RACEPAK's Avatar
Default S300 NEED help with wideband analog input, all i see in volts
hello
yesterday i connected the white wire on my aem WB to the S300 analog input connection on the S300 board, so i could view/datalog afrs,
then i went to the smanager analog inputs and in the convertion table i choose aem 30-4100. changes the units to AFR, uploaded the cal started the car and all i can see is volts, not actual AFR's
how can i fix this?
thanks
Old Mar 18, 2013 | 09:03 PM
mtber's Avatar
Default Re: S300 NEED help with wideband analog input, all i see in volts
I would suggest using the ecu's actual inputs for under closed loop advanced like D10 (eld) for your primary wideband input to make things easier :-)
Old Mar 18, 2013 | 09:16 PM
odz-fab's Avatar
does that datalog afrs with the d10 input? thats how i have mine wired up and it reads it foe closed loop but i dodnt think it dataloged it.. i may have missed it..
Old Mar 19, 2013 | 05:34 PM
RACEPAK's Avatar
i need it just for dataloging, i assumed it will be easier, thanks mtber
Old Mar 20, 2013 | 03:00 PM
odz-fab's Avatar
i lookd back at a few data logs and saw the top graph and switched through the graphs tabs.. under closed loop it appears it dataloged afr volts... so that helps. but not an afr number. i saved a afr/volts conversion chart to compare
Old Mar 30, 2013 | 09:55 PM
civic00a1's Avatar
I not gonna pretend I know alot about tuning, but I ran D14 then entered the AEM specs in the voltage, then set my offset to what my guage was reading, by the way it was an analog gauge
93redcb7
Engine Management and Tuning
10
Dec 6, 2012 10:28 AM
chefboyarluis
Mar 18, 2011 02:59 PM
ekcoupeh22
Dec 23, 2009 05:36 AM
underpressure02
Mar 10, 2005 01:39 PM
