Honda Civic dying while driving
Old Mar 14, 2013 | 04:15 PM
Cee Cee1's Avatar
Default Honda Civic dying while driving
Hey I'm not sure if this has been said before, but I have a 2000 Honda that cuts off on me while driving what could it be?? Fuel injector or stater?? please some one help me before I go to a shop...
Old Mar 14, 2013 | 04:50 PM
JKing106's Avatar
Catalytic converter plugged?
Posted from Honda-tech.com App for Android
Old Mar 14, 2013 | 06:28 PM
jonsey1886's Avatar
10 Year Member
Default Re: Honda Civic dying while driving
Le starter has NOTHING to do with your driving....it has only to do with your STARTING.
Fuel injectors (multiple) would have to plug, more likely plugged cat, dying/weak battery, low alternator output, or perhaps a loose MAF (airbox sensor) plug
Old Mar 14, 2013 | 07:02 PM
Emeraldbomber's Avatar
Does your car bog also?
Old Mar 14, 2013 | 07:22 PM
Racer02gtstang's Avatar
Even a possibility of a bad ignition switch. Do the dash lights and radio and everything turn off when the car dies
Old Mar 14, 2013 | 07:36 PM
B_Swapped93's Avatar
most likely the ignition. my dx did the exact same thing it scared the **** out of me at first.
Old Mar 14, 2013 | 08:37 PM
92 civic ex 4dr's Avatar
My eg did it. Turns out it was the stock anti theft system that wasn't even hooked up to The battery had ended up grounding out on the chassis killing the engine and immobilizing the starter.
Btw your car doesn't have a "stater" dirt bikes and quads and such do.
Old Mar 19, 2013 | 10:56 AM
Cee Cee1's Avatar
what does bog mean? it kind of jumps or acts like its back firing sometimes..
Cee Cee1's Avatar
no they don't go off
Old Mar 19, 2013 | 10:59 AM
Cee Cee1's Avatar
Just had my plugs changed and my filter.. but it still acts like it's about to stop on me.. it also back fires or stutters... what does that mean?
Old Mar 19, 2013 | 11:19 AM
Seems like a timing issue or dizzy issue
Old Mar 19, 2013 | 11:20 AM
OP did you ignore my post about it potentialy being the ignition....
Old Mar 19, 2013 | 11:25 AM
Most do, thats why I pretty much reinstated what you said. lol
Blackhead
Honda Civic (2006 - 2015)
Nov 2, 2018 12:46 PM
travelgal99
Apr 4, 2013 07:46 PM
hannibal1707
Honda Civic (2001 - 2005)
Oct 8, 2012 10:44 AM
Vtec Civic 93
May 23, 2010 10:58 PM
baz5
Sep 26, 2005 01:40 PM
