96 Accord fails CA low speed smog
Old Mar 14, 2013 | 12:06 PM
billybobdad's Avatar
Icon2 96 Accord fails CA low speed smog
My 96 Accord 4cyl failed the CA low speed smog (hi HC% & CO&) but passed the high speed test. Also got dinged for aftermarket cold air intake (fixed put oem back on). Any hints on how to remedy the low speed emission issue
Old Mar 14, 2013 | 08:33 PM
92 civic ex 4dr's Avatar
Could either be an o2 sensor not properly registering, or actually kinda sounds like your cat is going bad. At higher rpms the cat gets hotter working more efficiently. When i used to smog my vehicles i would always "super heat" the cat before it went in.
Posted from Honda-tech.com App for Android
Old Mar 15, 2013 | 08:09 AM
Default Re: 96 Accord fails CA low speed smog
"super heat" how do you do this ????
Old Mar 15, 2013 | 08:42 AM
Rev the engine at about 5k rpms for roughly 60 seconds
Old Mar 15, 2013 | 09:59 AM
MAD_MIKE's Avatar
MM Gruppe B
It's a five gas test, post up all the numbers of both 15MPH & 25MPH results.
Old Mar 15, 2013 | 10:48 AM
15 mph fail
%co2 meas 15.1
%02 .01
hc ppm 54 max 88 meas
co% .50 max .69 meas
no ppm 430 max 490 meas
25mph pass
%co2 meas 15.1
%o2 0.0 meas
hc ppm 37 max 37 meas
co% .47 max .17 meas
no ppm 717 max 331 meas
note car was driven 5 mi to test station & sat for approx 25 min before test
Old Mar 15, 2013 | 02:33 PM
MAD_MIKE's Avatar
MM Gruppe B
15 mph fail
%co2 meas 15.1
%02 .01
25mph pass
%co2 meas 15.1
%o2 0.0 meas
She's running rich, find out why and fix the issue.
Old Mar 15, 2013 | 03:56 PM
To narrow it down a little,
What are the possible causes for a rich condition???
Old Mar 15, 2013 | 04:19 PM
Bad up stream o2 sensor, timing off at dizzy, stuck injector (dirty and not closing all the way)
Old Mar 15, 2013 | 04:20 PM
I'm sorry. That's backwards. The fuel injector part. I have been doing mechanical work for 14 ******* years now. And i still get rich/lean mixed up.
Old Mar 15, 2013 | 05:27 PM
ReaperMan's Avatar
check the condition of the rotor. cap. wires. and spark plugs. might not be getting enough spark to burn all the fuel at low rpm. replace spark plugs with ngk's if you haven't done it in a while
Old Mar 16, 2013 | 10:14 AM
The results are inChanged the oil
Put in some hi ocatane gas
Put in a bottle of "Guranteed to Pass"
drove approx 125mi
got it hot
PASSED!Life is good today
Thanx for the tips
Old Mar 16, 2013 | 05:09 PM
MAD_MIKE's Avatar
MM Gruppe B
Thanx for the tips
What were the numbers?
*you can't leave us hanging with a simple 'it passed'*
rodvang
20
Oct 2, 2007 10:58 AM
ludecrasy87
Dec 16, 2006 11:51 AM
Herbie
Nov 6, 2006 07:45 AM
Blackhtch
46
Dec 30, 2004 12:02 AM
