1999 Civic Ex SRS, Idle, more.
Ok so last time i had a CEL(vtec pressure switch, and HO2S),battery draw, backup light not working, VSS stucked in 20mph when ignition in ON. Fixed the HO2S, it was a melted plug. Cleaned the switch and not sure yet if it fixed it cause i havent driven the car yet. Backup up light not working was due to a very bad corrosion on C401 and most of the pins are affected. Cleaned TB, IACV, Thermostat, filled new Coolant.
Now after removing the dashboard and every connector and put them back all together, SRS light is on. Dint even touch a single wire of the SRS. any idea whats causing this?
Idle fluctuating after running a few minutes. Any idea why? Bled the coolant for 15 minutes(saw the coolant swirl inside the funnel when fan turned on) not sure if it was air free cause i dont see bubbles anymore. Any idea? Help?
Oh and some of the wire from c401 has continuity to ground(tested with a self powered test light) it was connected to a junction connector, is it normal?
Bump. My only concer for now is the srs light. I didnt do anything on it besides taking the dashboard out of the car, which i certainly made sure that the srs didnt bump anything or was shaken bad. I had to unbolt the steering rack aswell and set it down really carefull. Imma try and get the code tonight. All i did to the wiring was tuck the one that goes to the gauge from the dashboard harness.
1-1: open circuited Or high Resistance In Drivers Inflatable Air Bag Module
(process similar, these are from 96-98 Civic FSM)
2-1: open circuited In Passenger's Inflatable Air Bag Module
yes. fixed it already. just did a reset/erase. thank you. it was probably because i started the car without the connectors plugged in and when i plugged everything back in, it saved the previous error.
iCollectStraws
Mar 1, 2010 08:18 PM
jdmboy96
Aug 18, 2009 07:12 AM
