Front speaker shorting out when door closes
Old Mar 13, 2013 | 11:45 PM
dweston's Avatar
Default Front speaker shorting out when door closes
I have a 97 honda civic and I just installed some aftermarket front speakers. It was working fine for about a week and now my headunit flashes "protect" whenever the door is closed. When it's open, it's fine. I thought it was a loose ground wire, but I've detached the speaker from the door and was able to play music when the door was open since I haven't run the wires through the door yet. Sure enough, when the door closes, the speaker "shorts" and the headunit flashes "protect". What's the root of the problem (other than not going to a professional) and what should I do?
Old Mar 14, 2013 | 03:07 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Front speaker shorting out when door closes
What do you mean you haven't run wires through the door yet? How are they run? Why aren't you using the stock wiring that is already IN the door? You don't have speakers powerful enough in a door that requires upgraded wire.
Old Mar 14, 2013 | 08:43 AM
NVturbo's Avatar
O.G. triple O.G.
it's technically not the wires but the PINS in the door jam connector. Replace the pin....problem solved.
Old Mar 14, 2013 | 10:29 AM
dweston's Avatar
The stock wiring on the driver's side isn't working. I've spliced in the wire that came with the speakers into the harness.
Old Mar 14, 2013 | 01:54 PM
The Grumpiest
I'm guessing that's your problem right there. Check your wiring.
Old Mar 14, 2013 | 11:11 PM
dweston's Avatar
I've rechecked the wires and made sure they were ok and they seem to be. In the process of doing this I've noticed a weird crunchy staticky noise whenever I close my door. A few months ago, I got into an accident and a motorcycle driver slammed into me and dented the driver's side fender (I think that's what it's called). I think that pinched the wires going to the door and is what is causing the problems I'm having now. I pulled the dented part back a little and now when I close the door the sound fades out and fades back in as the door is shutting.
This weekend I'm going to take the door off and repair the dent a bit more and maybe replace the pins as NVTurbo suggested. While I'm at it, I'm going to run the speaker wires properly. Is there anything else I should be looking for?
Old Mar 15, 2013 | 03:25 AM
NVturbo's Avatar
O.G. triple O.G.
dweston, if you're looking for replacement pins (and wires), grab them from a '96-up Civic. Don't get it from the door jam but behind the radio. They are the correct pins plus they aren't rusted at that location.
Old Mar 15, 2013 | 03:16 PM
dweston's Avatar
I'm guessing this isn't something I can just pick up at a retail store?
Old Mar 18, 2013 | 08:39 AM
NVturbo's Avatar
O.G. triple O.G.
NO....like I mentioned above, go to your local PULL-A-PART auto salvage yard and cut the pins (with 5-7" of wire) so you can solder the "new" pins in.
Old Mar 18, 2013 | 08:41 AM
gabriel0830's Avatar
im pretty sure its the wiring
Old Mar 18, 2013 | 08:46 AM
NVturbo's Avatar
O.G. triple O.G.
it is......at the door jam connectors.
Old Mar 18, 2013 | 08:48 AM
yupp i had the same problem until i did exactly what you told him to do and my problem was fixed
Old Mar 19, 2013 | 03:27 AM
NVturbo's Avatar
O.G. triple O.G.
The door jam wire pins are proned to corrosion even though they are covered with electrical protection spray. I had this issue in my old '94 4dr Civic.
Spawne32
Sep 5, 2009 10:15 AM
pez1
Apr 11, 2006 09:22 AM
93gsrhatchbrid
Audio / Security / Video
Apr 2, 2006 01:52 PM
tfalconier
Apr 10, 2004 06:45 PM
kysard
Mar 7, 2004 01:26 PM
