92 eg hatch clutch
So i have a 92 cx hatch with a d16y7 and im doing the clutch. i was seeing if someone could tell me some good brands to pick. i wana spend like 250$. Any help would be great.
Exedy is/was Honda's OEM supplier for most of their clutches, they make great stuff and you can find them on ebay for the price all day. Just pay close attention, some stores will say exedy presssure plate with another brand of disc in the fine print, check carefully and make sure both are exedy.
he was refering to the RPM drop between shifts if your shifts are slow it would affect it. ive drove in hilly terrain with a lighten flywheel no problem as well....
I just got a stage 3 Yonaka 6 puck clutch and so far so good..... i dont know what your plns are. if u plan to stay stock im sure u dont need a stage 3 and thats all yonaka makes... the yonaka clutch has a WAY stiffer pressure plate then the xtd stage 3.... XTD is ok but i had alot of clutch slip when it was new and i notice this yonaka clutch doesnt slip at all even when new. i dont recomend XTD they may be decent for a stock clutch only.
this is a stock 100hp motor that can barely get out of its own way.... any clutch will be fine... even if u went to your local parts store and bought a clutch you will be fine. if you were boosting the car or any other F/I then i would shop for a specific clutch for your goals.
Agree with Ryan It's just a Y7 why do you need a lightweight flywheel. or did you put a VTEC head on it ? even then just get a standred OE replacement save save some money.
All that I've read about flywheels(also looking into this upgrade w/in next year) suggests that any lighter than 14lbs is impractical for dd. Just trying to help- I've noticed a lot of people mentioning that initially leaving from a stop requires additional feathering to avoid stall on 10lb, in addition to feathering required for upgraded clutch. Revs will raise And drop faster as mentioned by apexi_rsx
Thanks for yalls posts. I see now that any other clutch is overkill on my d16. Ya its not boosted or anything this is my first time pickin a cluctch but now I get the jist of it when picking. Im gona get a exedy kit that comes with tha exedy flywheel for 290$. Does that sound about right?
VTecLude1994
Nov 7, 2008 07:12 PM
civicracer59
16
Apr 14, 2006 02:14 PM
redDAinteg
May 2, 2005 02:40 PM
