ZC MAP sensor help!!
Old Mar 13, 2013 | 02:22 PM
acadiasparta's Avatar
Default ZC MAP sensor help!!
i have a 91 crx with a pm6 ecu and 3rd gen zc engine. i just had it retimed, new dizzy, new plugs and wires. it idles good but when i give it gas it bogs out. the red light in the ecu is blinking 5 times. and when i pull the map sensor from the plug nothing happens and it stays the same. it is a used map sensor that i bought from ebay. the wiring by the ecu looks sketchy too. any advice on wiring from the ecu to the map sensor? thanks!
Old Mar 13, 2013 | 03:03 PM
4drEF's Avatar
Keyboard Humorist
Default Re: ZC MAP sensor help!!
Yellow/Red - C15
White - C11
Green/White - C14
Old Mar 15, 2013 | 02:42 PM
jlicrx's Avatar
code 5 is for the vacuum portion of the MAP - code 3 is for the electrical portion - check your vacuum hoses
Old Mar 15, 2013 | 02:58 PM
4drEF's Avatar
Keyboard Humorist
Good catch jlicrx!
mr2turbo007
Apr 23, 2012 06:22 PM
HndGoob
Mar 7, 2005 12:19 PM
91bluehatch
Jan 25, 2005 08:22 PM
SiRWannabe
Aug 9, 2003 09:12 AM
