Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
ABS code after replacing wheel bearing
Old Mar 13, 2013 | 06:39 AM
tehemsath's Avatar
Default ABS code after replacing wheel bearing
How does 09 civic ABS system measure movement of right front wheel? Installed new wheel bearing and now keep getting right front wheel sensor failure, bought new sensor and get same code. Can't see any tooth sprocket to count pulses from like most cars.
Tom
Old Mar 13, 2013 | 07:00 AM
97emsedan's Avatar
Default Re: ABS code after replacing wheel bearing
Maybe the sprocket is further up the drive shaft, check to see if it is next to the output on the transmission.
Old Mar 13, 2013 | 07:44 AM
m_shake's Avatar
From the FSM,
NOTE:
Install the wheel bearing with the wheel speed sensor magnetic encoder (E) (brown color), toward the inside of the knuckle.
Remove any oil, grease, dust, metal debris, and other foreign material from the magnetic encoder surface.
Keep all magnetic tools away from the magnetic encoder surface.
Be careful not to damage the magnetic encoder surface when you insert the wheel bearing.
You most likely put the bearing in backwards.
Old Mar 13, 2013 | 10:00 PM
EG8R's Avatar
The wheel bearing is installed backwards. There is a magnetic ring on the bearing that the abs sensor reads off of. Will most likely need a new bearing now. When taking out the old bearing it usually comes apart.
B_Swapped93
Suspension & Brakes
Sep 28, 2018 07:52 AM
Wstroud
Jun 5, 2018 05:13 PM
joeromero0
Sep 27, 2011 03:19 PM
suspendedHatch
16
Aug 11, 2009 05:17 PM
WRTEG
Apr 28, 2005 03:04 PM
