just picked up a 88 4dr dx have a couple of questions
Old Mar 12, 2013 | 05:29 PM
tonylovesjdmEF9's Avatar
Default just picked up a 88 4dr dx have a couple of questions
So I just came up on a 88 ef sedan its a dx model with ac and ps stock everything just have a couple of questions ……
It doesn't have a radio or radio harness
Would a 91 si sway bar fit when I throw on the si lcas ??
Old Mar 13, 2013 | 06:37 AM
4drEF's Avatar
Keyboard Humorist
Default Re: just picked up a 88 4dr dx have a couple of questions
I believe the radio harness is there. You will just need to look for it inside the console.
Rear sway bar requires the rear sway brackets. The LCAs are the easy part.
There aren't threaded holes for the brackets to mount into.
Easy fix is to just get an aftermarket bar.
To mount the stock bar, you will need to cut holes through the floor of your trunk so that you can put nuts on the backs of bolts.... not required if you use an aftermarket bar.
Old Mar 13, 2013 | 06:45 AM
Alright thanks bro cuz I just bought this for 1300 clean title and no radio checked and I didn't see a harness hanging around in there center consolet but ill pop the center console off and see what I could do ……
Alright well I got all of the si rear sway bar thanks for the info
VeilSide_Mas
Aug 19, 2006 03:39 PM
Turbo Dan
Oct 24, 2005 02:18 PM
crexer
Aug 30, 2004 07:03 PM
jtl
16
Apr 12, 2004 07:43 AM
CRexcellence
Dec 2, 2003 05:14 PM
