Which oil pump?
Old Mar 12, 2013 | 04:26 PM
aavtec's Avatar
Default Which oil pump?
Basically I got a b18b short block which was rebuild for ls-v but the original owner left it in his shed with no spark plugs and the cylinders rusted There is no way for me to contact the original owner so I am trying to figure out what kind of oil pump this is.
Old Mar 12, 2013 | 05:11 PM
lacrosse12's Avatar
Default Re: Which oil pump?
From what I've seen, all b-series oil pumps have the same part number so wouldn't they all be the same?
Old Mar 12, 2013 | 05:12 PM
1998GsRIntegra's Avatar
96+ are all the same, before that, they were different.
Old Mar 13, 2013 | 04:44 AM
aavtec's Avatar
Anyway to tell if this is a ls or vtec oil pump?
Old Mar 13, 2013 | 05:41 AM
kyden's Avatar
pull it apart and check for a spacer between the relief spring.
but i wouldn't reuse an oil pump, they're cheap enough.
Old Mar 14, 2013 | 01:46 AM
aavtec's Avatar
The oil pump has never been used before. The previous owner assembled the motor but never ran it. What do you mean "pull it apart and check for a spacer between the relief spring."?
Old Mar 14, 2013 | 12:36 PM
user 34938202's Avatar
if you remove the screws out of the back and remove that plate you can pull it apart . All 96+ are the same
Old Mar 18, 2013 | 04:37 AM
wreckeddc4's Avatar
No way that filthy pump was never ran... Never trust previous owners claims.
Old Mar 18, 2013 | 07:30 AM
Brandon_ek's Avatar
Never re use an oil pump but it def is an ls oil pump
Old Mar 18, 2013 | 09:55 AM
Disco's Avatar
Ok I gotta know why you say not te reuse an oil pump? I would not reuse the one that this guy has in the picture because he doesnt really the real history of the pictured pump.
But as far as re-using a pump that I know the history of is not out of the question. I have been using the same pump that I bought from honda 6 years ago and has been in 5 different motors. None of which ever blew up and I have never spun a bearing so the pump is in great shape. I always disassemble my pumps and inspect them for any cracks or scaring. I have had more than adequate oil pressure all the time.
Old Mar 18, 2013 | 01:04 PM
Brandon_ek's Avatar
When buying a bnib pump from Honda and you yourself know how it's been used reusing it is ok but from someone else's swap that's a no go always buy a new pump when buying swaps , personal preference
Old Mar 18, 2013 | 07:12 PM
b19coupe's Avatar
Somebody has been telling you stories. Take what ever BS the seller told you and throw it out the window. As someone else said, get a new pump. It is too critical a part not to replace. Cheap insurance. Too many fresh builds die a nasty death when corners are cut.
Old Mar 22, 2013 | 01:38 AM
rich7777's Avatar
Why not open it up and inspect it? It maybe fine...
Old Mar 22, 2013 | 04:36 AM
Disco's Avatar
What he said
Old Mar 25, 2013 | 12:23 AM
kanggoiseng's Avatar
all B series using same oil pump
Mefain
May 16, 2003 09:02 AM
