Transmission fluid recommendations?
Old Mar 12, 2013 | 03:44 PM
Skatnshawn's Avatar
Default Transmission fluid recommendations?
I have 97 auto accord any recommendation on what fluid to use? Ive searched but no luck, not really wanting to spend a fortune on Honda brand if I don't have to.
Old Mar 12, 2013 | 04:33 PM
HondaAccordKen's Avatar
Default Re: Transmission fluid recommendations?
I've been reading good things about Valvoline MaxLife® DEX/MERC ATF.
http://www.valvoline.com/products/co...ssion-fluid/37
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
Old Mar 12, 2013 | 04:41 PM
CD5B2's Avatar
You could use dexron, but that's not recommended for long term use. Go with Honda ATF-Z1 or ATF DW-1. ATF DW-1 came out in 2011. My '97 has ATF-Z1 since 2010 and it's pink still. Probably get it changed this spring.
Old Mar 12, 2013 | 05:53 PM
19Accord97's Avatar
There are 1,000,000,000 threads on this
Old Mar 12, 2013 | 06:03 PM
djkurious's Avatar
This
Old Mar 13, 2013 | 05:12 AM
charliccs's Avatar
I change the transmission oil to my accord 96 1 month ago. I put honda atf dw-1
and it`s ok...
I think is the first time for the transmission only have 58k miles...
I was scare for the oil change but thank`s god no problem so far...
Old Mar 13, 2013 | 07:32 AM
JamesB1985's Avatar
Use the Honda OEM Automatic Transmission Fluid. No exceptions. Do it,.
Old Mar 13, 2013 | 05:20 PM
Skatnshawn's Avatar
Ok thanks for advice looks like most say Honda, what about b&m? I will get Honda if I have to but the price is ridiculous, somebody needs to make a good competition
Old Mar 13, 2013 | 06:30 PM
netopia's Avatar
Doesn't Honda just stick a label on the bottle and sell it as there's?When every other auto fluid has the same additives just different makes.
RicksHonda001
Jul 2, 2017 02:50 AM
xpdude
Feb 22, 2010 06:17 PM
PerryRT
Nov 24, 2008 01:46 PM
ramoneguru
May 2, 2005 02:34 PM
qwklude82
Jan 4, 2003 11:26 AM
