Stiff front and OEM rear
Please offer me a theory or text book answer on this set up.
Stiff front springs and OEM rear springs.
FWD, 60/40 distribution, 3,600lbs.
What would handling be like? Track and DD street.
The stiffer the front is relative to the rear, the greater the understeer tendency will be. Since almost nobody wants more understeer than stock, for most people and most cars it would be a bad idea to stiffen the front without also stiffening the rear.
In broad terms it will mean weaker turn-in and the front end will "give up" more easily in turns. You'll also get a slightly stiffer ride in front.
Let me slide this in. Then wouldn't adjustable coilovers be a bad thing?
Yes, owners can adjust to whatever setting they like. But the settings could be all wrong in terms of handling and safety, no?
I could be wrong about this but I suspect the problems with badly adjusted dampers probably have less to do with steady-state handling (i.e. steady-state understeer/oversteer) and more to do with dynamic changes in handling, like if you hit a bump or change the load on the suspension. So it's not a direct analogy to stiffening the front springs, if that's what you're getting at.
I would guess that 95% of people with badly adjusted dampers have them underdamped. I think it's also safe to say that many people who change their suspensions do it for cosmetic reasons, sacrificing ride comfort, performance, AND safety.
I'd say more people have them overdamped, especially for performance driving. They crank the dampers up expecting that they'll perform like stiffer springs, and to the inexperienced driver they will. They also think that stiff means better handling, when it usually doesn't.
Let's not forget weight transfer as well. It's a catch 22 really because:
- During braking, you want a stiff front (keep weight off the front end).
- However, during acceleration in a FWD car you want a stiff rear (to keep the weight on the front end which helps with tractive forces).
This is why (for example), the ITR is a very neutral car at the brink of oversteer. Front and rear spring rates / sway bar sizes are very similar.
lol, you just basically called everyone that runs stock class in autox inexperienced.
