How to do the timing on a D15b swap?
I have an ED6 with a D15b Swap and My timing is off causing crazy bogging, but my main problem is I can't find the yellow jumper plug that you need to jump in order to do the timing right!
are there any step by step instructions on how to set timing for a OBD0 d15b VTEC?
Ok here we go
1. Start engine and allow to reach normal operating temp
2. Remove the YEL rubber cap from the ignition timing adjusting connector, located at the rear of the engine
3. Connect a jumper wire between the BRN and GRN/WHT terminals of the connector
4. Connect a timing light and check timing using the red timing mark
5. Timing should be 16-20 deg
6. Adjust timing as needed, by turning the distributor
7. Turn off engine
Hope that solves it man good luck
7. Turn off engine
My problem is that I Dont have the Beige Timing covers I Only have the top one that covers the timing belt but I havent installed it yet, do I need these to do the ignition timing? Please help
