95 accord clutch problem
Old Mar 12, 2013 | 08:06 AM
bc77711's Avatar
Default 95 accord clutch problem
I have a 1995 accord ex manual and replaced the clutch, pressure plate and throwout bearing 2 days ago. It has been driving great up until today, my fiancee left work only to make it about five miles and called me saying the car wouldn't go anymore. I had her switch through the gears while the car was off to make sure he shift cable was working and the slave cylinder which all looked as if it was working fine. I also cgecked the fluid which was full, im not sure how far the rod to the slave cylinder is suppose to go out but when she had the clutch pedal down i could pull the rod out another 1/2 inch or so. Idk if that would be a problem or not. Someone please help because im at a loss.
Old Mar 12, 2013 | 05:01 PM
bc77711's Avatar
Default Re: 95 accord clutch problem
Thanks for the quick feedback but i figured it out
Old Mar 12, 2013 | 06:41 PM
92 civic ex 4dr's Avatar
What was the problem? Had i have seen this earlier i would have told you to bleed the system.
Posted from Honda-tech.com App for Android
Old Mar 18, 2013 | 01:18 AM
bc77711's Avatar
I had replaced my axle a few days earlier and it was bad. It slipped out of tge differential nd luckily didnt do too much damage so they warrantied it out and now its running great but thanks.
Golddigger
Dec 16, 2013 04:58 PM
oldschoolsdime
Oct 11, 2006 07:10 AM
HONDA92HATCH
Oct 22, 2004 04:12 PM
92'gsrhatch
Feb 22, 2004 05:36 PM
