93 del sol s d15b7 mods - best bang for $700?
Old Mar 11, 2013 | 01:47 PM
souchiem's Avatar
Default 93 del sol s d15b7 mods - best bang for $700?
Just picked up a 1993 del sol S with d15b7 motor. i have 7oo$ to modify it. no swaps or minis what can i do to get the best bang for my buck? engine wise. bolt ons. im new to this stuff. thanks a lot in advance.
Old Mar 12, 2013 | 11:38 AM
mrspeedy69's Avatar
Default Re: 93 del sol s d15b7 advice
Honestly just leave it alone. Put that money towards something else or towards maintenance so it'll stay running well for a long time. There's no use in trying to make these things fast.
Old Mar 12, 2013 | 07:13 PM
fonkernuckle's Avatar
With a b7 in it, I would buy some rotas or some very light wheels similar, since the sol is rather heavy. Best bang for your motor would be a z6 or y8 intake manifold and definitely a very light header all this can be had for the way less than 700.
Old Mar 12, 2013 | 07:52 PM
Emeraldbomber's Avatar
The best bang would be a turbo but thats out of range. Save it for a turbo or maintance
Old Mar 12, 2013 | 08:33 PM
eghatch9295's Avatar
Stancetard Hate Monger
do nothing. enjoy your 700. bolt ons will do NOTHING. i know you're anti swap, but a z6/y8 can be had for 4-500. you could afford a t belt, water pump, and oe clutch kit and be in budget
Old Mar 13, 2013 | 06:51 AM
strategy400's Avatar
Hey at least your back window rolls down...
Old Mar 13, 2013 | 06:54 AM
grumblemarc's Avatar
The Grumpiest
Nothing for that. Put it into suspension.
Old Mar 13, 2013 | 12:03 PM
eoin3629's Avatar
intake mani is fairly good in b7's, but header, exhaust, CAI etc... mini me very cheap n you get an extra few horses for it, i wouldnt cross it out
Old Mar 13, 2013 | 12:12 PM
If its an automatic tighten the kickdown cable adjustment a halfturn to move your shiftpoints about 200 RPM higher to tap a better powerband. Then take the $700 and put it into your engine swap savings account and drive the B7 like you stole it.
The Grumpiest
I would. It's a waste of money for "power" you'll barely feel and NOT feel at all later when you get used to it.
Old Mar 14, 2013 | 07:22 PM
souchiem's Avatar
Thanks for replys, mini is already crossed because not internally inclined to do so. Suspensions already been done. But the intake manifold sounds like something I can do. I have seen some with turbo manifolds without all the other turbo accessories, is that sufficient I'm power or just a waste of money?
Old Mar 14, 2013 | 07:26 PM
The Grumpiest
No you haven't because there's no such thing. Maybe a fancy looking header is what you're talking about.
Still a waste of money but since you're dead set on trying to get performance that isn't out there for the money you have then just start buying parts.
Old Mar 14, 2013 | 09:56 PM
souchiem's Avatar
Haha nevermind researched it, it was throttle body? No intake weird . But any other suggestions?
Old Mar 14, 2013 | 09:58 PM
souchiem's Avatar
Nvm it was throttle body but didn't have an intake on it. Anyways any other suggestions? Aftermarket cams or plugs? How about supercharging ?, don't really see any of those!
Old Mar 15, 2013 | 02:43 AM
The Grumpiest
Get all of that since you're being hard-headed.
Old Mar 15, 2013 | 03:18 AM
jbpnoman's Avatar
The cost of supercharging a D series would be the same as turbo, and is still outside your budget. Nothing, I repeat nothing you do to that engine will increase your performance without forced induction, and $700 will barely get you properly tuned, let alone get all the necessary hardware. If your suspension is "done" as you put it, spend that money on a full tune up, and bank the rest of it.
Old Mar 15, 2013 | 03:29 AM
NVturbo's Avatar
O.G. triple O.G.
instead of "modifying" it, replace all the maintenance stuff like spark plugs/wires, gaskets, water thermostat, timing belt, etc.
Old Mar 15, 2013 | 07:08 AM
Whydid's Avatar
My suggestion is to just spend some of that $700 on a VHS copy of The Fast and The Furious. With the remaining money, buy a camera with which to take pictures of all of the horrible rolling mechanical failures that are 99% of the modified Hondas on the road.
Post these pictures on car forums with accompanying text that says "UHHHHH, HELLO! These guys modified their cars and they're clearly very fast. How can I get to such a level of fastness? Do I need NOS like Paul Walker?"
For a more advanced level of tune, also buy a copy of The Fast and The Furious: Tokyo Drift and then ask about what you need to do to your Civic to drift.
Old Mar 15, 2013 | 12:01 PM
please take my advice. don't boost the b7. it has limp dick rods, it is really a throw away engine for anything other than d/d status.
Old Mar 15, 2013 | 12:03 PM
you seem stubborn and ignorant. this forum is loaded with people with years of experience, myself included. anything that you slap on that motor will do nothing but cost you money, and be shiny. if you do not want to swap the motor, don't waste your time trying to "go fast"
Old Mar 15, 2013 | 08:08 PM
toni_the_kid's Avatar
z6 intake manifold and ex/si tranny is about it besides mini which is a waste or swap which you don't want so just keep the money and do maintenance and pocket the rest
Posted from Honda-tech.com App for Android
Old Mar 15, 2013 | 08:24 PM
Hamza_Z'sTuning's Avatar
Broo what I would do is see if your motor is healthy for boost than get a turbo kit off ebay depending on how healthy the motor is I would do 8lbs you would be making over 180whp.Bro thats what my friend did when he had a stock ef he didnt have much money so he threw in a turbo kit off ebay and no one at his school coult keep up!
Old Mar 15, 2013 | 08:44 PM
I wouldn't do a ebay kit but that's me. if he shopped around he could piece it together. id only use the intercooler and piping off ebay and that's it but either way a b7 isn't that good of a boosting motor.
Old Mar 16, 2013 | 12:31 AM
Whydid's Avatar
This is Honda-tech so I have to just ask for clarification: this is a joke post, right?
Old Mar 16, 2013 | 01:29 AM
gzes's Avatar
U can get a whole car with a d16z6 for 3-400... A cherry picker for a $100 and a couple days in the weekend or get a buddy to do the swap and pay them the rest for labor. Its easy swap tho. B7 sucks as i have one in the civic i have. I payed $300 flr the parts del sol for my red del sol and put the z6 in it. Pretty easy since all the hoses are different sizes so you can tell what goes where and same with the plugs
