Need help on spacers
have a honda civic si 2000
gonna be drop 2.5 all round
rim 15x8 0 offset
fender rolled all around
tires 195 45 15
just wonderring if 20/25 mm spacers is to much?
any suggestion will aslo help?
thanks
rim 15x8 0 offset
tires 195 45 15
thanks
Without the spacers that is going to look incredibly stupid with a 2.5" drop. A 20-25MM spacer will reduce the offset to at least -20.
The idea of low offset wheels w/ stretched tires is make the rim come as close to the body as possible without the tire getting in the way. This requires lowering the car significantly (4"-5"). You're doing it wrong.
i also have front and rear camber.
i doubt its gonna loook bad
well see if im doin it wrong.
my car is alrdy drop with 2.5 all round with 17 inch tires with no camber
and no rub issues at all.
reason i post a tread up cause i just bought a set of 15x8 0 offset and i want to know how it works with spacers on em.
this my ride drop with 2" on 17s
https://www.facebook.com/photo.php?f...type=3&theater
Halo
Dec 25, 2004 04:29 PM
